Question about Konica Minolta Office Equipment & Supplies
Error code c0200 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Replace the transfer/ sepreration wires
open close front door to reset
Posted on Dec 30, 2015
3 Suggested Answers
goalie39
  • 469 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
firecontrol7
  • 6161 Answers
SOURCE: I have a minolta EP 2080 Copier an error code appeared C0200 what should I do Thanks for your help
Open and close the front door.
Posted on Feb 22, 2012
How to remove error C0200 on bizhub c350?
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
How to remove error C0200 on Minolta bizhub c350?
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Error code c0200
The error code C0200 deals with the transfer or separation charge corona wires. I would replace the two wires and see what happens. The code can not be rest till the problem is fixed. Good Luck
Nov 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
I see this message on the screen. A malfunction was detected. please call technical Rep code: C0200 what should i do if i don't want to call?
Code C0200
Description
PC Drum Charge, Image Transfer, Paper Separator Corona malfunction
Detection Timing
The leak signal (SCD) turns ON after the PC
Drum Charge and Image Transfer/Paper Separator
Corona output has been turned ON.
Try this:
C0200: Corona Malfunctions
Relevant Electrical Parts
  • High Voltage Unit HV1
  • Master Board PWB-A
Jul 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
Getting error code: c0200 on my ep6000. what is the problem?
check the corona wire of charging assembly/ transfer assembly maybe the corona wire is broken if its broken replace it to remove error code
Dec 14, 2010 | Minolta Office Equipment & Supplies
C0200
Corona wires are used in the transfer/sep assy and drum charge. C0200 is code if they fault. To reset the machine open and close the front door, if ithe code comes back the corona wires and or assy need replacement
Feb 19, 2010 | Konica Minolta DiALTA CF910 Copier
Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Nov 12, 2008 | Minolta EP1030/1030F CS/PRO Copier
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
