Question about Jensen Car Audio & Video
I just want to know how to bridge a amp - Jensen Car Audio & Video
Put a positive from the left sub in the positive slot then put the negative from the right sub and put it in the negative slot the take the other positive and negative and twist them together and cap them off.
Posted on Jun 19, 2009
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
Feb 18, 2010 | MTX Thunder 801D Car Audio Amplifier
I have a mtx thunder 81000d amp i need to know if i can bridge it
Hello frank_sadach,
"Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
Hope this helps.
Oct 23, 2009 | Car Audio & Video
Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Bridging 2 amps togerther
Not all amps can be bridged together. If the amplifier is capable of being bridged with another amp, the owner's manual will explain how to do it.
Let me know if you have any other questions.
Aug 21, 2008 | AudioBahn A1300HCT Car Audio Amplifier
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Jun 02, 2008 | Audio Players & Recorders
Bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
Mar 27, 2008 | Car Audio & Video
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Hifonics X generation galiath old school
Find your manual here: http://www.maxxsonics.net/manuals/hifonics/ Next tell me the exact model number of your subs and type of box they're in Be sure to leave good feedback or I don't get paid
Sep 28, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
