Question about GE Profile JB988 Electric Kitchen Range
Cracked rangestop glass assembly replace
REMOVING AND REPLACEMENT OF RANGE TOP GLASS ASSEMBLY
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
These can be tricky, first remove everything you can from the glass top then very carefully using two small screwdrivers like tyre levers gently go around the outside & the glass top will lift off.
Posted on May 08, 2014
IFIXALL
  • 868 Answers
SOURCE: Replacing Glass Cooktop on GE JPB82
1st....You have to pull out the cook top first.2nd...remove the 1/4 inch screws that hold the top down(they are mounted on the side os cook top ) ,you dont remove the lowest ones.remove the burners from the top and your there :) Please Rate This !
Posted on Jun 07, 2008
MNTECH
  • 1543 Answers
SOURCE: Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Posted on Aug 31, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
iwillfixforu
  • 619 Answers
SOURCE: Broken Glass on Cooktop
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
Posted on Mar 01, 2010
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
BROKEN RANGE GLASS ASSEMBLT REPLACEMENT
Third time today. Remove all burners ,everything you can remove from the glass top, then use two small screwdrivers as tyre levers go around the edge and the glass top will lift off.
Apr 17, 2014 | GE Kitchen Ranges
Glass top range is pitted and scratched from an abrasive cleanser. Can it be replaced. It is a whirlpool freestanding range about 2 years old
Yes, your glass top assembly on your range can be replace. Here is one link where you can get the part, http://www.apdepot.com/Products/PartsLookup2/IPLLookupFrames.aspx?Brand=WHIRLPOOL&ModelNo=GR399LXHS1&ImgID=EdI2&ImgFile=WTKIKKLL
It is a relatively easy job to replace the main top since the burners are not attached to the top assembly itself. Remove 2 or 3 screws on the front of the top and you can easily lift the entire top off of the range and replace it with the new top.
Apr 17, 2011 | Whirlpool GR399LXHS Electric Kitchen Range
The Schott glass top is cracked - where can I replace it?
I will assume you are talking about the glass top on a range..If so they are not cheap..they range from 600.00 to 1,000 for a replacement top.
Dec 19, 2010 | Whirlpool Ovens
How come my canon mp830 printer prints a black line on left side when using ADF?
there are many possibilities that you will have to check out for: 1)either there is any dust got collected in the ADF assembly.so that dust is also coming in the prints. 2) of there is any thin object like hair got stuck up in the inner side of the ADF assembly.so whenever the print comes this copy of hair comes in every print out. 3) also there can be a slight crack in the ADF glass assembly.so this slight crack is giving the line in prints. 4) also the other reason can be that the black cartridge is low on ink.in this case it needs replacement of cartridge or the cartridge refilling. ----- so the first step you can follow is that you take a cleaning brush and clean all the dust on the upper ADF glass assembly where you place the paper.then take a moist tissue and clean the glass of the ADF assembly. then check out.if still the same problem then take a air blower and blow the air in the inner as well as outer area of ADF assembly and check out.if still the same problem then check out if any crack on the ADF assembly glass.if no crack then its the fault in the inner side of glass.for this the assembly and printer both needs to be disassembled.but this will require proper tools.its advisable to get it done by local printer/copier repair technician familiar with this brand/model. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 09, 2010 | Canon Office Equipment & Supplies
Glass top burned through
Yes, the top is available as a replacement part. You can check the link below to narrow down your exact range model number, as there are about 51 variations for this model series (you'll need the letters/numbers at the end of the FEF366 to zero in on the parts list).
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=N9LEW3Qt6z2wIPtmEnod-w**.shcapp3106?modelNumber=+FEF366+&pop=flush
The cost for a new glass top is around $220 plus S&H (+/-). It is a relatively straightforward removal and replacement process, where all you need to do is disconnect the range from the power plug and pull it out from your counter, etc. and remove the rear fastening screws that hold the backsplash onto the top surface frame and exchange it for the replacement top.
Just be carefull when removing the old, broken top, as the glass will likely shatter more as you remove the frame. Wear safety glasses and work gloves to prevent getting cut, etc. All you need are simple hand tools to do the repair.
I always like to state that you might want to consider the age of the stove before committing a couple of hundred bucks to buying a repair part, but you have to decide if you're looking to keep and repair your stove, or whether you want to get a new one - the decision is yours to consider and make. Just a little FYI.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Frigidaire FEF366 Electric Kitchen Range
GE profile top
Yes, the glass cook top can be replaced. These counter top inserts are actually fairly simple to repair, but the entire assembly usually has to be uninstalled to accomodate removing the glass top and installing a new one. You will need to provide a model number by opening the cabinet underneath the cook top and looking for a nameplate in order for me to assist you further in determing a part number, cost and how to disassemble.
Aug 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Inner door glass replacement
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3 Remove the inner screws. Keep all set of screws ordered, and take note of the order you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Apr 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
GE Profile JB988 Electric Kitchen Range Logo
149 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
