Question about Sony Playstation 3 (PS3) Console
PS3 switching itself off
While playing my PS3 switched itself off. I can't turn it back on as it shuts down on startup. I have power lights so not an input problem i think. PS3 has not been bumped in any way. Any help would be appreciated, cheers
  • greg911 Jun 19, 2009
    no warranty but thanks for the help, will contact sony.
  • greg911 Jun 20, 2009
    Hi mate, tried removing hard drive and turning on. No difference, blinking red light
    President:
  • 2,653 Answers
Let me guess...
You get a blinking red light then it shuts off.
Your system probably overheated and unfortunately Sony has it setup so that when it happens you have to send it in for service.
Are you still under warranty?
Posted on Jun 19, 2009
  • 3 more comments
  • RescueTechLA
    RescueTechLA Jun 19, 2009
    Try booting the PS3 with the hard drive out.
    Let me know if you get anything different.
  • RescueTechLA
  • RescueTechLA
  • RescueTechLA
  • RescueTechLA
    RescueTechLA Jun 20, 2009
    OK, then it's for sure a hardware issue with the motherboard.
    You'll have to take it to Sony for repair.
    1-800-345-SONY
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
My playstation switched of during game play now it wont turn on whrn i hit the on switch it turn green then orange and the console shuts down
if ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3... this kind of problem u can fix by using repair guide easily...........
click here to download
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not turn on at all
your PS3 probably overheated. it does this with 2-3 hours of nostop play. you need to cocheck it every 20-30 mintues after one hour and take breaks to let it cool down, so it doesnt malfunction. i would take it to somewhere like Game Stop and have it shipped for repair. i would also leave it unplugged and not try to turn it on, for the risk of further damage.
Nov 15, 2009 | Sony Playstation 3 (PS3) Console
My ps3 keeps shutting of by itself and i dont know
switch off console and hold the power buttom down till it beeps twice .then release it and immidatley after that hold it down again ,
then u will have recovery menu which enables u to reset ps3
(harddrive will get wiped out)
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont eject just turns itself off
Try booting the system while holding the power on button. Hold the button and keep it held until it turns off. After the system shuts off, try turning it on normally. Let me know if this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
I was playing the bigs 2 when suddenly my ps3 started to shut off.I turn it on again it wont turn back on.The red light just keep on blinking.
Turn the PS3 power off via the switch on the back.
Hold the power button on the front of the machine down for about 15-30 seconds.
Then, without letting go of the power button on the front of the machine, turn the switch on in the back.
If it still doesnt come on then you may have serious problem with PS3 in which contact Sony or the retailer you bought it from for exchange or rapair.
Jul 27, 2009 | Video Game Consoles & Games
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
20 g japanese ps3, its turning itself off during startup and red light is flashing.
this could be down to the need of more power from your plug as when i use my power convertor it needs to be on high rather then low otherwise teh console doesnt power up
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
383 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
