Sanyo dp42841 my screen is cracked. how much is a new screen? if possible
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: sanyo dp42841 is making a crackling noise
determine first if with sound off you have the problem---if not it is audio related and if with sound off it is still there it is inside the set....
Posted on Mar 30, 2012
SOURCE: My tv went completely out. Is there a reset button
Try unplugging it. That is usually the reset.
Posted on Apr 02, 2012
SD Tech
  • 14553 Answers
SOURCE: i have brand new sanyo 42
If brand new and have some issue or need something call customer service for this set--if missing something contact also the place where it was purchased.
Posted on Apr 23, 2012
Sanyo 42'flat screen model DP42841 makes noise when you turn it on
If still under warranty then call them about it. If not then try and determine where the noise is coming from. I suspect it could be the power supply area. Most of these modern sets are only a few boards that can be replaced. It's just a question of determining which one.
Jun 08, 2018 | Sanyo Televison & Video
I have a Sanyo Model DP42841 and I want to know how to stop the texting that comes when people are speaking?
If your source is the TV (RF input), then the Caption button on the original remote for the DP42841 will let you cycle through the available closed caption options. If you have a universal remote, you'll need to find a code that lets a Caption (or CC) button work with this TV. This is shown on page 8 of manual. ManualsLib has the manual here: https://www.manualslib.com/manual/148706/Sanyo-Dp42841.html .
If your source is any set-top box, you need to disable the captions on that source. This can depend on the system setup. I know that on one satellite dish receiver, the captions for a second TV on the system had to be enabled from the primary TV. (Then the captions showed on both TVs.) On a IPTV set-top box that I use, to disable the closed captions, I need to enter the Settings menu using a pass code from the provider. Then the setting is under Audio.
I hope this helps.
Feb 09, 2018 | Sanyo Televison & Video
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
My Sanyo DP42841 P42841-06 TV screen fades out to black. Can you help?
If you come to me with that set, I'm sure that I can make it right.
But, no way; you can, or you will make it right. OK?
Sep 11, 2016 | Sanyo Televison & Video
New (2012) DP42841 Sanyo no sound
Check all the cable connections to audio board for any loose connection. During long term storage, this might have happen. Reset all that cables comes to go out from it. If it do not help you, check the speakers. If all found OK, replace the audio output card. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy. Check its audio settings too. Whether it is muted or not.
Jan 05, 2014 | Sanyo DP42849 42 in. HDTV
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
I have brand new sanyo 42
Apr 23, 2012 | Televison & Video
Sanyo dp42841 is making a crackling noise
Mar 29, 2012 | Sanyo Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
