Question about HP Office Equipment & Supplies
CANON IR 3245 CODE E 00007-0000
CODE Eoooo7-oooo
2 Suggested Answers
  • 159 Answers
SOURCE: My photocopy Canon ir 3245
Unfortunately, it may be a hardware problem, most likely the fixing film unit which can be costly.
You may want to try the following, it may be a temporary fix:
* Press the head key (the head with the star inside)
* Push 2+8 together and then the head key again - this should get you into service mode.
* Select 'COPIER' then 'FUNCTION' then 'CLEAR' then select ERROR or ERR press OK
* Then switch the machine off and on again.
I hope this helps.
Best of luck!!
Posted on Mar 02, 2011
How to change Laser In canon ir 3245 When printout it totaly black.
Hi. I think that the laser unit doesn't cause that problem . First check the drum unit maybe there is dirt In the contact points
May 24, 2017 | Canon Office Equipment & Supplies
WHAT HAPPEN ON IR 2202 FOR THIS EOO2-OOOO AND HOW CAN IRSOLVE IT?
E002-0000 Low temperature during temperature control.
The target temperature is not reached during temperature control. - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the
Aug 20, 2014 | Canon Image Runner 2022 Copier
Eoooo7
Film not rotating replace film
Jun 27, 2013 | Canon imageRUNNER 2200
Canon ir 3245 error code e000280-0003
Reading unit communication error.Disconnect and connect zhe flexible cable,if not good,replace it
Feb 05, 2013 | Canon Office Equipment & Supplies
Canon ir 3245 errorcode 000007
replace the fuser film or grease a film
Jan 10, 2013 | Canon Office Equipment & Supplies
Which copier should I buy -- a Canon 3245 or a Bizhub423
my opinion Canon, lower service hours, better performanse, toner is onecomponent, so that means that you dont need to change developer...
On net find the technical specification and compare... the Canon is Canon!
Aug 19, 2011 | Canon ImageRunner 3245 Black and White...
Canon ir 3245err 000024-0001 how to solve it
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
u can do this steps : Disconnection of the wire used for detecting the connection of the
toner level sensor is found.
When the disconnection of the wire used for detecting the connection
of the toner level sensor has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop cassette feeding).
of the toner level sensor has been detected for 12.5 min without
interruption
if it is problamatic you have to replace sensor.
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Ir 3245 slow printing on pdf files
This may require a firmware update or even try printing the PDF file from a different version of Adobe.
Jun 25, 2009 | Canon Office Equipment & Supplies
55 people viewed this question
Seeker5211
Seeker5211
