Question about Haier HLP140E Electric Portable Dryer
REPLACING THE DRUM BELT
NEED ASSISTANCE ON WHERE THE DRUM BELT GOES...THIS IS WHAT I KNOW NOW.....PUT DRUM BELT AROUND DRUM....UP ON THE WHITE PULLY...THEN WHERE?
  • Patti Mann Apr 20, 2014
    I DID NOT CHECK FOR OTHER PROBLEMS, BUT I DID GET THE BELTS BACK ON AND IT IS WORKING OKAY NOW. AT 60 YRS OLD I GUESS I SHOULD JUST FEEL BLESSED I WAS ABLE TO GET BACK UP OFF THE FLOOR AFTER HAVING TO PUT BELTS ON! THANKS ALL FOR ADVICE , APPRECIATE SO MUCH....IT HELPS TO KNOW WHAT I AM DOING ...LOL
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
First belts are not as easy as they appear. But beside the belt the support runners that support the drum my be bad. when you replace the belt, did you take the entire dryer apart and inspect it for more problems?
Posted on Apr 19, 2014
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 80 Answers
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Posted on Apr 17, 2014
Testimonial: "THANK YOU SO SO MUCH........I DID IT....IT WENT ON OKAY. BUT ...NOW THE MACHINE SOUNDS LIKE THE BELT IS RUBBING SOMEWHERE....AND I DO NOT SEE THAT THE ORANGE FAN BELT I REPLACED IS MOVING ...SHOULD IT BE? I INSTALLED THAT BELT BY GOING AROUND THE BACK DRUM BAR THAT IS LONG AND IN THE MIDDLE OF BACK OF DRUM.....THEN PUT THE BELT AROUND THE WHITE PULLEY THAT IS ATTACHED TO BAR. I THEN PULLED THE FAN BELT UP TO THE BLACK PULLEY WHICH IS THE FRONT PART OF THE METAL PULLEY. IS THERE SOMETHING I DID WRONG HERE TO MAKE IT SOUND THIS WAY.....IT DID NOT SOUND THIS WAY BEFORE . BUT IT DOES HEAT AND WORKING.....I APPRECIATE THIS SITE AND THE HELP SO MUCH......THAT YOU JOHN SO MUCH FOR YOUR CORRECT AND GOOD ADVICE~!!!"
Haier 6.5 current ft dryer, how do you put the belt on after it came off?
if its still wrapped around the drum an drum turns with it fine .. see the white idler belt goes on bottom then around the motor idler.
take the right side of belt an pull it around motor an down an under the idler .
Oct 12, 2014 | Dryers
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
The dryer does not spin even though it starts and gets hot.
hi, the problem you are having is going to be with the belt that goes from the drum to the motor, if you can turn the drum freely by hand without any friction then this suggests the belt has snapped and needs replacing but if how ever when you turn the drum by hand their is some resistance then this could mean the belt has stretched or the motor has failed either way your going to need to get the back off to have a look.
let me know how you get on or if you need further assistance ok
Jun 04, 2010 | Whirlpool LEB6300 Electric Dryer
I NEED EASY ACCESS OR ENTRY TO REPLACING DRUM BELT DRYER
depending on your model . the frt panel must be removed to access the belt. belt goes around top of drum down th
o the btm over the motor pulley then thru your idler pulley. if this does not help or need more info, send us model # that will help .
Sep 23, 2009 | Maytag Dryers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
My dryer needs a new belt. I opened the front panel and removed the broken belt but I am not sure how to put on the new one. I know it goes around the drum but does it go in the middle or near the back...
Cheryl the belt goes in line with the pulleys. 1st Put the belt around the drum. 2nd put the belt around the pulley on the motor. 3rd pull down on the idler pulley and set it so that is pushes on the back side of the belt. Remember the ribs on the belt go against the drum. When done the pulley will take up the tension on the belt. Hope this helps.
Aug 09, 2008 | Dryers
I have a broken drum belt,but I don't see how to put the new one on.I see where it goes,but unable to figure out where and how to start it. Whirlpool LEN2000KQ Electic Dryer
Before replacing the belt, purchase a new idler assembly, the one in there is what caused the belt to fail so soon.
Replacing the belt with one person takes a little practice as you have to hold the drum in place while holding the pulley in the slots on the bottom panel and place the belt over the pulley and attach to motor shaft. The diagram shows how the belt is routed:
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Whirlpool Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Haier HLP140E Electric Portable Dryer Logo
247 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
