Question about Refrigerators
Maytag mff2558kew Both Fridge and freezer will not cool
    Novelist:
  • 150 Answers
Do you hear the fan running in the freezer? Use a small flat blade screwdriver and gently insert in to the freezer center curved grille at either end to release, there is a center tab too at the bottom, you will see the fan blade, if it is not turning, rotate it by hand to see if it spins freely. If the fan blade is spinning very slow or not spinning at all, most likely this is your issue. You can test the white and blue wires at the fan plug for 110 volts AC. If the fan is rotating at much faster speed, check for excess ice/frost on the white freezer cover that the curved grille snaps into. Excess frost/ice could be an indication of a defrost issue caused by more than one failed part. Defrost failures can be caused by a failed defrost thermostat, heating element, or the Jazz control located in the fridge which is the digital display. Pleazer Appliance...
Posted on Apr 17, 2014
    New Friend:
  • 21 Answers
There could be a number of problems, you need to have your refridgerator topped up, or your elliment went, another solution, check to make sure that nothing is blocking the fan in your freezer
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
  • 531 Answers
SOURCE: my maytag fridge model number msd2657hes wont cool
you have defrost problem
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
  • 2699 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Maytag bottom freezer upper fridge fridge stopped getting cold freezer is fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Fridge Maytag model msd2454GRW - Refrigerator not cooling, alot of moisture buildup in fridge. What is the symptoms of the defrost timer sticking on.
heatman101
Aug 21, 2011 | Maytag Refrigerators
Our Maytag fridge (top freezer) is losing coldness in the refrigerator, the freezer is still very cold. This has been going on for 3-4 days and is getting worse...
heatman101
May 17, 2011 | Maytag Refrigerators
I have a Maytag fridge MTF2193arw, the freezer is nice and cold with the fan working, but the fridge is not cold with no air movement.The unit is 3yr
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Maytag Refrigerators
Hi , i have a Z sidie by side maytag fridge/freezer my fridge section is freezing up even though the setting is now on 2.but the numbers are flickering,for both freezer and fridge compartments. l...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 10, 2010 | Maytag Refrigerators
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
