Question about Frigidaire PLMV169DC Microwave Oven
Frigidaire prof. series microwave PLMBZ209GCA not working. Display comes on. No sound (fan). Dont know if microwaving function is working properly or not. Any suggestions?
  • 33 Answers
Two things could have happen to your machine.
One the magnetron is dead and needs replacement.
Second the high tension power which supplies power to the magnetron could have been screwed up and need to be replaced or repaired.
The fact that the fan is not running I suspect it may be a power board issue.
Posted on Apr 19, 2014
SOURCE: Frigidaire FMV156D 950 Watts Microwave
check or replace magnetron
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire microwave light turns on, fan does not, does not heat
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 28, 2008
  • 38 Answers
SOURCE: Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Posted on Mar 15, 2009
SOURCE: frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Posted on Apr 27, 2009
miket756
  • 2702 Answers
SOURCE: Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
Posted on Jun 06, 2010
Sounds like fan blade hitting somethinWhat is wrong?
I appreciate your inquiry, Gloria armstrong!
You stated that your fan blade inside of your Frigidaire microwave is hitting something. It is difficult to provide you an accurate diagnosis with properly disassembling your microwave. This is not a simple DIY job. I would highly recommend seeking assistance from a professional technician. They would have the knowledge on how to properly disassemble your microwave without causing any future harm to your microwave. I hope this is helpful. -Matt
Feb 21, 2015 | Frigidaire Microwave Ovens
PLMBZ209GCA Professional Series microwave: the timers and lights all work but NO Microwave?
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
Feb 01, 2013 | Microwave Ovens
Frigidaire microwave not heating over the range
Hello
Try to cook something simple such as microwave popcorn. If the unit does not light up or turn on, check the outlet with another appliance to make sure the outlet is functioning correctly.
Check the fuses or circuit breakers in you house. If the outlet does not work after testing it with another appliance, try to plug the microwave in a different outlet.
Check the hinges and door hooks to make sure the door is closing properly. Look to see whether a small piece of food is clinging to the door, preventing it from closing all the way. Check the release mechanism and the rotating plate to make sure they can move freely as well.
Plug in the microwave and start it a the bag of microwave popcorn inside. If the lights go on but it is not producing heat, listen and try to hear whether the unit sounds the way it usually does. If it does not, there might be problems with the circuit board. This will need to be repaired by a certified Frigidaire professional.
Check the display that shows the time and power. If the display is flickering but it does not alter the operation of the microwave, it is not a problem. If, however, the lights flicker and your food is not heating, there may be a problem in the microwave cabinet.
Listen for buzzing sounds. If there is a buzzing sound and no heat is being produced, you may have to get a new magnetron, power diode, or high-voltage capacitor. These can be purchased from a Frigidaire retailer.
Look at the handle on the door. The most common complaint about all models of the Frigidaire microwave, according to Consumeraffairs.com, was cracked or broken door handles. Frigidaire will replace faulty handles while the oven is under warranty. In many cases, they will replace the handle even after the warranty expires for a "reasonable" amount of time.
Oct 04, 2011 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=--=-=
May 19, 2010 | Frigidaire FMT148G1 Microwave Oven
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
Noise problem
Do you mean the hood / vent fan? If so, it may be failing, or there may be an obstruction in it.
Yours may have a fan-like stirrer located above the cover in the ceiling of the microwave. Is that what you mean?
Is it heating and working properly otherwise?
Please reply back so we can help further.
Dec 04, 2007 | Frigidaire GLMB209D Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
151 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
