Question about Samsung ML-2851ND Laser Printer
RESET XC1045 HOW TO RESET XC1045
Xc1045 reset
Panel
Clear Button
Auto
Clear
Auto
14
Start
Apr 17, 2014 | Xerox Office Equipment & Supplies
I have a Xerox Copier XC1045. Our copies are coming out with dark spot on the paper., I change the drum, but still have same problem, even big area has black spot
You may have a worn out heat roller in the fuser.
It is also likely you have a bad toner cartridge . If the spots are gritty then replace the toner cartridge and vacuum out the machine,
Aug 11, 2010 | Xerox 5665 Copier
How do I get rid of the annoying fault code 07-515.00 The Bypass Tray is empty.
I HAVE A XEROX XC1045 CAN YOU SHOW ME THE SYMBOLS THAT COME UP SO I CAN ASK THE QUESTION ON THE SYMBOL IT LOOKS LIKE A CHECK THE PRINTER WONT PRINT
Apr 30, 2010 | Xerox 5665 Copier
Getting an H4 Error code on my Xerox XC1045 copier. Any Suggestions?
This will most likely clear it. If not then the heat rod in the fuser most likely went bad.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. Program the copier as if you were going to make 14 copies.
  7. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  8. Run a test copy.
  9. repeat 1-7 more than once to be sure it has worked properly.
There was incorrect info in this I copied and pasted. I corrected it.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox xc1045 copier machine
If it starts to make a copy and the light comes on then stops in the middle there is a problem w/the connection.
check the cable that turns on the light it may have a cut and is not making contact in a particular spot. If not then it may be the board that controls the lamp.
Oct 17, 2008 | Xerox 5665 Copier
Flashing H3 on XC1045
have you tried a hard reset?
please leave the unit plugged off for one hour and then on the unit
Sep 29, 2008 | Xerox Office Equipment & Supplies
Samsung ML-2851ND Laser Printer Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
