Question about GE Monogram ZDI15C Automatic Icemaker
My ZDIS150WSS ice machine will only produce cut ice through the door. How can I get it to change back to whole pieces?
5 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Ice maker isn't making ice...
there appears to be a problem with 1. the temperature needs to be turned down to produce Ice. also is the fill tube frozen where the water goes into the ice maker sometime you have to thaw it to get the ice out of it and the reset the maker too. Let me know if this helped and if it did not don't rate and ask another question from me and I'll be galad to help. If it did would you please rate this solution please. Thanks for using FixYa.
Posted on Jan 01, 2009
  • 7 Answers
SOURCE: Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
muntejaya
  • 10421 Answers
SOURCE: bad humming noise for ge
It is problem with your compressor motor. Please check and fix the compressor.
Regards, Jay
Posted on Apr 20, 2011
  • 489 Answers
pretty big job to replace compressor on this refrigerator. Thats video I made on one of my customers monogram. Hope That helps.
Posted on Aug 23, 2015
Lights on front of refrigerator seem to be locked. nothing works when you push one but lights are on and the temp area states the same 39
You are looking at a bad selector switch and or the door switches that activate the auger to push the ice out. You would be looking at replacing the whole control if you need the ice to come out of the door. I would first try the simple unplugging and plugging back in, sometimes resetting the unit can help clear it up. Good luck
Sep 09, 2012 | Refrigerators
Bad humming noise for ge monogram ice maker zdis150wss. stopped working entirely.
Apr 20, 2011 | GE Monogram ZDI15C Automatic Icemaker
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jan 01, 2009 | Refrigerators
Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Oct 28, 2008 | Amana Refrigerators
My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Oct 04, 2008 | Refrigerators
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Ice door won't open
Wow, what I job "i know". Even though its a new door it is possible for the sitch(#13) to be burned out. Also look at diagram. you may have bumped something loose! goodluck dd7d24c.jpg
Dec 16, 2007 | Maytag MZD2766GES Side by Side...
It could be the water valve at rear.check water supply to valve,
if that's ok,you could change valve at rear
Nov 30, 2007 | Whirlpool ED2FHEXN Side by Side...
GE Monogram ZDI15C Automatic Icemaker Logo
90 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
