Question about V6 Radar And Laser Detector - Black
Just pull it out my work car put in my truck the cord blink once the radar wont power up
Working fine all day just stop working
    Problem Solver:
  • 17 Answers
Sounds like a dirty receptacle. If you're a smoker, I guarantee that's the problem. Take the cigarette lighter fuse out of your vehicle and clean the receptacle with sandpaper wrapped around a small stick. Good luck!
Posted on May 07, 2014
2 Suggested Answers
  • 134 Answers
SOURCE: My Belltronics radar detector stopped working.
It sounds like you have a power issue for the power cord. Either the power cord is not getting any power, or it no longer has a good ground connection.
Posted on Apr 24, 2009
Stopped working
What stopped working? Does the unit power up? Is there no sound? Will the unit not alarm any more?
If it stopped working, did you check the fuse in the units' power cord or the vehicles lighter socket fuse?
If not sound, does all the other lights and buttons function? if so, is the volume control turned up?
Aug 14, 2010 | DE-1793 Radar Detector
I have a 2001 saturn sc1 that is having intermittent starting problems. At times after its been driven ill go out to leave again and it won't start. No clicking when I try and start it either. Wait for...
I am having the same problem. did you figure out what was wrong with yours. I have tested all of the wires in the harness under the dash, they r fine. I pulled off the starter and had it tested; O'rilies said it was fine. It is a 5 speed, and I can push start the car just fine any time. Like yours, some days my car starts, some days it doesn't. The days it starts, it runs fine with no problems starting or running. the problem is the days that it wont start.
Feb 25, 2010 | 2001 Saturn S-Series
Cobra XRS 9950 Radar Detector not powering up
At the end of the power cord for the radar detector the end screws off and there is a fuse for the radar detector itself. Check it....
If that isn't the problem post back for further help.
Thank you for choosing Fixya!
-dan
Mar 19, 2009 | ESD 6100 Radar Detector
I have a Solo Radar Detector and all of a sudden when you insert the batteries and turn it on, it goes through the motions of turning on, then when done, the solid red light just blinks. I don't have a...
Well first off in doing so removing the batterys before you powered it off its stuck in some kind of error mode. Try putting the batteries in, holding the power button down for a few seconds and see if the light stops blinking.
Second Idea if you have a local radio shack they have replacment power cords for radar detectors there about 10 dollars. I had to go buy one for mine. After powering it up with that Id say it should work fine.
Feb 22, 2009 | Passport 8500 Radar Detector
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Aug 13, 2008 | Philips 42PF9431D/37 TV
Power light blinks
I found a solution, Heat. When the set is on and heats up it stays on, but once off for the night it gets cold and can't start, try using a hair dryer on full blast and put the heat around the back top vent like structure and wait for the light to stop blinking, this only takes about 2 min or so
Sep 05, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
V6 Radar And Laser Detector - Black Logo
88 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
