Question about Vintage Keeper 220 Plus Wine Cellar
Can't set properr temperature.
Can't set temperature.
Dell vostro 1015 audio jack
you have to go to audio sound setting and select headphone
Apr 03, 2014 | Dell Vostro Computers & Internet
Just dopes not work properrly seems to hangup then scro;ll several places up or down
if you have a touch pad for your pointing device, it sounds warn. I suggest a external usb cordless mouse and it will by pass the touch pad and you will be good as new a good cordless mouse 15 bucks tops.
Sep 30, 2013 | Computers & Internet
Ac in my 2005 colbalt is overcharged what do i do the compressor keeps kicking on and off
using a set of manifold gauges, remove some 134a form the system-it is the only way to fix this properrly.
Jul 01, 2011 | Chevrolet Cobalt Cars & Trucks
I successfully replaced the freezer door but cannot get it to seal.
Possible that the alignment was not done properrly with the hinge settings. SO first of all release the hinge sccrews and adjust the seal part to coincide then tighten once by one with minor adjustments.
Oct 31, 2010 | GE Profile PSS26PSTSS Side by Side...
Front brakes lock up
sounds like your calipers are not relasing properrly, replace both pads, rotor and check calipers and relplace them too if needed
Oct 09, 2010 | 2004 Kia Optima
Reformat computer
you have to format the system and reinstall the windows. i hope you will be find the solution.
Feb 02, 2010 | Computers & Internet
Toshiba satellite L305D-S5881 Fail to connect to a camera by usb
insttall the corect driver if you dont have download from the internet, that is dirver only not intalled properrly
Sep 07, 2009 | Toshiba Satellite L305D-S5881 Notebook
Car wont turn on
i solved this issue by putting the wires on the starter the properr way silly oversight but i got it fixed thanx to anyone who offerd advice thanx fixya
May 18, 2009 | 1994 Pontiac Sunbird
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Bios set 08-08-2008 resets to 31-07-2007 every time i turn computer off.turn computer off then turn on it resets its self to 2007.turn power off and on at power switch. computer starts on own i do not push...
- do a bios update (or downgrade if needed) to see if it fixes the issue
- but probably the BIOS battery is not keeping the proper voltage anymore, and it automatically resets the BIOS (do the bios setting that u change, remain changed after unpluging/pluging the comp ?!). Try keeping the computer pluged in for a day and see if the battery charged properrly (if the set date remains )... if not ..change the battery.
- as for the self starting, there is a setting in the BIOS, that activates/dissables that ! - see u;re user manual ...
Aug 08, 2008 | Computers & Internet
Vintage Keeper 220 Plus Wine Cellar Logo
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
