Question about Beltronics Vehicle Parts & Accessories
Using wrong power cord
Just to it out my car plug it in to my truck and the cord light blind once and goes out the radar detector wont power up
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Please describe the product and color of the wires
Posted on May 27, 2014
  • 20 Answers
Power cords for small electric devices supply a specific combination of volts and amps (milliamps) to the device. Most power cords of this type are actually mini step down transformers used to regulate the voltage/amperage to a pre determined level that matches the device, using a cord that has a lower volt/amp level may do nothing as the power level is not high enough to power the device, but using a cord with a higher than specified level will almost certainly destroy the sensitive electronic components (resistors, capacitors, etc.) inside making the circuit board that controls the device useless. Check your device and owners manual for a reset switch (I doubt it has one though), or if it is valuable, you may want to search for an electronics repair store (they are getting hard to find) and see if it can be repaired. This applies to most all small electronics from phones to computers, use the supplied power cord, and if you purchase an aftermarket power supply device make sure the voltage/amperage numbers match exactly. In the end saving a few dollars on a cord can be very expensive.
Posted on May 08, 2014
    Problem Solver:
  • 17 Answers
Sounds like a dirty receptacle. If you're a smoker, I guarantee that's the problem. Take the cigarette lighter fuse out of your vehicle and clean the receptacle with sandpaper wrapped around a small stick. Good luck!
Posted on May 07, 2014
SOURCE: Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
Posted on Aug 06, 2007
IrishDruid
  • 2712 Answers
SOURCE: Uniden LRD9100SW Radar detector
You can try:
Uniden America Corporation
Parts and Service
4700 Amon Carter Blvd.
Fort Worth, TX 76155
(800) 297-1023, 8:00 a.m. to 5:00 p.m. Central Time, Monday through Friday
Posted on May 25, 2008
  • 6 Answers
SOURCE: Beltronics Vector 995 does not start
They don't have batteries. :d.
Posted on Nov 08, 2008
SOURCE: Cobra radar detector speaker replacement
I called cobra support(777-889-3087) and it was around $6 plus shipping for a replacement speaker.
the correct phone number for cobra support is 773-889-3087 and can be found on their website.
Cobra was very courtious and I also got my replacement speaker for my XRS-9500.!
Posted on Nov 13, 2008
ButtFuzz
  • 463 Answers
SOURCE: reading the radar detector
These are just the frequency ranges, or "bands" that your detector is detecting the frequencies...
X, K, Ka (Kappa-Alpha) are different bands of frequencies.
Posted on Mar 12, 2009
Sonic Cobra 360 10 band laser radar detector doesn't work two cords of power is it radar itself does notwhat could be wrong
Maybe the fuse for the accessory port / cigarette lighter is blown. Check the fuse map for your car and confirm if the fuse is good or not. Or, if you have another device that uses the port, plug it in and see if it gets power.
Nov 21, 2016 | Cobra Vehicle Parts & Accessories
Wont power on at all i think my cord shorted out is it repairable
see if you are getting 12 volts at the point where it plugs into the radar detector if not replace cord otherwise replace radar detector.
Aug 12, 2015 | Bel Professional Series GX65 Radar...
Wont power on
Have you pressed or pushed in the Power button? have you checked the radar detector's power cord fuse? Its located in the plug part of the cord. If that is ok, have you checked the lighter socket? Does it power other 12 volt devices?
Aug 12, 2015 | Vehicle Parts & Accessories
Just pull it out my work car put in my truck the cord blink once the radar wont power up
Apr 17, 2014 | V6 Radar And Laser Detector - Black
Whistler 1783 detector shuts as soon as it goes thru start up mode. seems to get very hot to touch.
Try the factory reset - hold in the power and quiet buttons, while holding in these buttons plug in the power cord. Unit should beep twice. The unit will get warm to the touch.
Aug 22, 2011 | All Band Laser-radar Detector Radar...
Whistler 1730 keeps blowing fuses. no other problems with cigarette lighter plug
Is the lighter socket fuse blowing or the fuse in the unit's power cord? Have you tried another power cord from a Friends radar detector? If it doesn't blow that power cord's fuse, then your power cord is bad. If it does blow the fuse in the other power cord, there could be something wrong with the unit. Contact Whistler at info@whistlergroup.com
Jun 15, 2011 | DE-1730 Radar Detector
Whistler 1480 does not power up.
Does the lighter socket power other devices? If so, did you check the fuse in the units power cord? Its in the plug part that goes into the lighter socket. Its a 2 amp fuse.
Jul 10, 2010 | 1480 Radar Detector
Laser goes off when i am driving in area were there is no buildings or police cars also goes to k ban what is this problem
A lot of the time this is caused by a somewhat flaky power connection to the radar detector, or may be caused by excessive electrical system noise created by your car's alternator. The cigarette lighter socket itself my be the problem due to oxidation within the socket. Do you get false laser alerts when you rev your car's engine to certain RPM's? Do you get either laser or radar falses if you jiggle the radar detector's power cord or slightly move it plug in the cigarette lighter socket? If yes, to either, then installing a hardwire power kit may solve the problem. Jump over to radardetector.net and describe the problems you are having with your radar detector. Most likely they will help you to track down the source of the problem.
Jun 25, 2009 | Passport 8500 Radar Detector
Broken Cord plug
you can buy new ones on ebay
Apr 01, 2009 | BEL 980 Radar Detector
Vehicle Parts & Accessories Logo
140 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
