Replace my floppy drive with a USP emulator drive. I
Have swapped out the drive and put ribbons back the way they were but the machine is not reading the drive did I leave out a step. My machine has the current 4.01 update I'm just at a loss....
sandrew
  • 2961 Answers
SOURCE: Machine won't recognize CD-ROM after harddrive format
You have to change it in the bios, press F2 or DEL on startup depending on your bios type. The bios screen then will have second line of advanced bios settings, in here you need to select the cdrom as the first boot device, by using the up down arrows or pageup/down or '+or-' keys. Press ESC when cdrom selected and save settings when propmted. The system will re boot so ensure the cd is in the drive and press enter when prompted to start with cdrom.
Posted on Jan 29, 2007
nichu
  • 170 Answers
SOURCE: floppy drive
hello fergus this is nichu
nowadays floppy &flopy drives are getting outdated hence first find out whether if your system is detecting the floppy drive or not,if not then you have to go to a hardware engineer to solve this problem ,it is so simple and it wont take much time .since floppies are getting outdated you will get those drives installed at a cheaper price
Posted on Nov 04, 2007
  • 133 Answers
SOURCE: how can i update the bios on a dell inspiron 1000
you can set the computer up to boot from the CD drive
Posted on Apr 21, 2010
  • 5603 Answers
SOURCE: floppy disk drive emulator usb
The floppies in most of the music instruments are NOT quite compatible with the USB floppie emulators.
Posted on Feb 21, 2011
Fhearghuis
  • 43 Answers
SOURCE: my hp zt 1170 battery
Try tapping the F12 key during boot. That should bring up a menu of bootable devices. Select the floppy drive.
You can also change the boot order in the BIOS.
Make *absolutely sure* you are plugged in when you flash the BIOS!
Posted on Mar 21, 2011
How to connect 34pin floppy emulator for 24 pin floppy driver?
best to buy a floppy disk drive with direct USB cable to avoid all these problems and is recognised by PC for booting etc. No emulation required.
Oct 06, 2014 | Computers & Internet
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
Jan 17, 2014 | Korg Pa50 Professional Arranger Keyboard...
I own a Korg Triton Classic. I just replaced the touch screen on it. Now it wont read the floppy disks...any suggestions
It is VERY easy to not have gotten the cables back and seated completely for the floppy disk. ALSO it is very easy to damage the ribbon cables on floppy drives by pulling at the edges of the ribbon to pull connectors off. One MUST distrbute the force all across the cable as it is easy o damage the connections in the connector for the wires near the edge. It is also easy to damage the pins on floppy drive connectors. You will need to reopen the unit and check the cables INCLUDING the little power cable to the drive. If you have damaged the ribbon cable you can either replace it or possibly get another connector and put it on the cable right next to the one with the problem and crimp it in a vise... These are an insulation displacement type so you need to get it on straight and ALSO verify the index is the right direction before crimping. For your problem think cables, cables, cables...
Jan 26, 2011 | Music
I have panasonic floppy disk drive type JU-257A727P its green light is lit continously
The ribbon-cable connecting to the motherboard is "backward".
Swap the cable end-for-end, and reconnect it to the motherboard.
Dec 10, 2010 | Panasonic (JU257A607P) (JU257A607P)...
EmachinesT2792 Can the floppy drive be replaced with out removing
You should be able to replace the floppy drive from within the computer case. Open the case be removing one side, unplug the ribbon cable connecting the floppy drive to the motherboard and the power cable connecting it to the power supply, and slide out the floppy drive. There may be screws holding it in place that need loosened first.
Jul 21, 2010 | E-Machines T2792 PC Desktop
I need to replace my floppy drive on a yamaha psr 9000 keyboard
Why.. get a USB floppy.. if you go inside a PC and pull a wrong wire your PC will be toast. Get a USB floppy. Why are you using floppies anyway? Get a USB stick for $8, way less then a replacement floppy and much safer.
Jul 16, 2009 | Computers & Internet
Need to format 720
In a DOS prompt type:
format a: /n:9 /t:80
That should format the disk at low density for you.
Apr 07, 2009 | Dynex DX-EF101 (DXEF101) External Floppy...
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
