Question about NEC Office Equipment & Supplies
Push lamp door sensor manual on nec np1000
How can I push lamp door sensor manual on nec np1000 ?. I do not have the lamp cover, so it does not turn on.....
4 Suggested Answers
  • 736 Answers
SOURCE: NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Posted on Oct 07, 2009
eddiepeezy
  • 130 Answers
SOURCE: NEC NP1000 projector: In a corporate
There should be a menu setting to flip the image vertically. Check the menu settings.
Posted on Feb 04, 2010
caroldon
  • 17129 Answers
SOURCE: Our NEC projectors have the little broken piece on
There is a tiny trigger switch which gets activated when the door is closed and switches the main controller to work and power ON. So if this damaged you need to seeif this can be mended with a superglue or if not the door plastic can be recreated. if not the door can be ordered from NEC.
Posted on Sep 29, 2011
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
How can I get the best video image quality with Nec np1000 projector ?
Your best option is using the COMPONENT IN input of the projector (Y, Cb, Cr). Though the highest video signal the projector will support is 1080i.
May 09, 2014 | NEC Televison & Video
Service manual
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 31, 2014 | NEC (NP01LP) Projector Lamp for NP1000,...
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have...
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector central.com helpful, where the owers manual for the MT 1030 is available in PDF version.
http://www.projectorcentral.com/NEC-MultiSync_MT1030+.htm
May 13, 2010 | NEC MultiSync MT1030 Multimedia Projector
NEC NP1000 projector: In a corporate meeting...screen display is upside down! Help?
Feb 04, 2010 | NEC NP100 Projector
NEC GT6000 LCD PROJECTOR
check the lens cover hood to see that it's on correctly, and that the lamp door is closed. if they are, check the switches. on the hood and the lamp door, there are plastic protrusions that hit the switch activators. if they are broken off or warped, you need to replace the door/hood. if they are there, check the switch itself. replace as necessary.
Nov 17, 2009 | NEC GT6000 Multimedia Projector
Oct 07, 2009 | NEC NP100 Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
35 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
