Question about RCA P61940 61" Rear Projection Television
No sound There is no sound coming from the front speakers most of the time but when I do get sound its static
    Scholar:
  • 195 Answers
May have a corrupted EEPROM.
Posted on May 08, 2014
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Boston acoustic ba7500G speakers only giving static!
The cables are color coordinated, and also make sure that there is no loose connections.
Jan 07, 2010 | Boston Acoustics BA7500 Computer Speakers
Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Jan 15, 2009 | Yamaha RX-V661 Receiver
2.0 CH USB POWERED SPEAKER SYSTEM
The static is probably coming from the computer sound card itself. Turn the volume down on the computer mixer it should limit the static you are hearing.
Jun 07, 2008 | Audio Players & Recorders
Sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 20, 2008 | Logitech Z-5500 Computer Speakers
Samsung HLN567W whining sound from front bottom middle of tv
Hi
Here is the steps that I will suggest you to check.
Mute the sound completely and make sure sound is not coming from speakers. If you totally concluded that sound is not coming from speakers probably its from internal coils on the circuit or high voltage cable leaks statical electricity. that case asking assistance a qualified hands on technician will be best idea.
Good Luck
Jan 04, 2008 | Samsung DLP HL-P5663W 56" TV
Sound problems
are you sure you have plugged in the speakers properly? maybe u inserted the cable in the wrong port or u just didnt insert the cable property. A loose connection can cause static and obviously it wont play anything. Please check.
Dec 24, 2007 | Harman Kardon HK19.5 Computer Speakers
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
RCA P61940 61" Rear Projection Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
