Frigidaire Affinity ATF6000F Front Load Washer Logo
J
JERRY TEMPLEMAN Posted on Apr 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lights on power board stays on after machine shuts off, now machine stops and unlocks door in cycle
Ashwan Ramanand
Level 2:
New Friend:
  • Expert 75 Answers
  • Posted on Apr 18, 2014
Ashwan Ramanand
Expert
Level 2:
New Friend:
Answers
75
Questions
0
Helped
47659
Points
152
Hi, this could be a factory fault, where the capacitors are still holding current after shut off. It would be best to check the warranty and return the item asap. Good luck.
1helpful
2answers
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Washer wont complete cycle
Sound like the control board is bad
I want to stop my machines cycle. How can I unlock the door?
you have to evacuate all the water. there should be a stop cycle position or button maybe press the start button twice, i am not sure on this model . the macine will then pump out the water and stop after a minute or sothe door should unlock. if the water is still in the machine it will stay locked.
I hope this was useful.
I have a hotpoint aquarius extra washing machine. The door will not unlock, I have turned it of over night and it still doesn't unlock. I have checked that the water has drained and unblocked a sock from...
This would suggest that the lock is getting a signal from the control board telling it to stay locked, which would explain why the "spin light" is on as the control board does believes the cycle has not finished its in your signal board sorry
2helpful
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
2answers
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Cycle runs normally but the washer does not stop after spin
I don't know specifically about your machine but I think the problem is with the door lock. Again, on most machines with a shakeout it can go on and on until the door unlocks. Does your machine have a door UNLOCKING solenoid or does the door lock just lose power at the end of the cycle. It may be that you just have a very weak solenoid to unlock the door.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
