Question about QUANTUM FX ANT-105U HD / DTV / UHF / VHF / FM 360 Degree Motorized Rotating Antenna
No reception Was working.but suddenly quite
Get my Sky reception back
You may have to check or adjust the alignment of your sky dish.
Mar 02, 2015 | Televison & Video
Only 2 FM stations working. I have an Insignia Stereo receiver. At first, we could get all of the FM stations, then all of a sudden we can only get two. The antenna has not been moved from where it or
If you have an external antenna, check you antenna connections.
Weather can change your reception. Are the stations you can hear local? within 30 miles? Or is there an amplifier on your antenna system? It may have quit functioning. if you have cable TV you might want to hook up your stereo to that system, you will need a 75 to 300ohm adapter that you can pick up from an electronics store or online.
(coax to twin lead)
Sep 27, 2014 | Audio Players & Recorders
Marelessall of sudden, my remote mouse quit working, What happened?
First, Ascertain that an observation has least caused the device from fucntioning. For example, observe the device for physical malfucntions, ascertain that battery resources has least been malalliged to prevent regular functionality. Replace batteries that are depleted of capacities taking care to place the appropaite directions usually demarked on the battery and within device compartment area. Second, remote control device require appropiate direction toward receptable display device to capture signals. For example attempting to transmit remote signals from distance extrenously without receptables reach is least attainable. Also, the remote control has a transmittion sensor area also similar with the receptable display device. Malalligning either transmitter to receptables least captures signal responses when any made available. Refer to the devices user guide attain diagnostic materials amonsg pertinent details on attaining an improve television experince.
Feb 17, 2011 | Logitech 931307-0403 Remote Mouse
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
I have a GSS25WGMD the display on the front suddenly quit.
It sounde like the main control board quit communicating with the dispensor board . I would replace the main control board Pt # WR55X10942
Aug 12, 2009 | GE GSH22JFR Side by Side Refrigerator
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
No reception on phone anywhere all of a sudden
contact your cell phone provider (att, sprint, verizon). your service may be shut off.
Jul 11, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
No radio reception on 2003 Audi A-4 Cabriolet Convertible
After reviewing the feedback on these postings I identified the problem them took it to my local car stereo shop. I showed them how by raising and lowering the trunk the signal went in and out. They fixed it for $60 by splicing in some new coax cable. It works great.
Dec 14, 2008 | 2003 Audi A4 Cabriolet
QUANTUM FX ANT-105U HD / DTV / UHF / VHF / FM 360 Degree Motorized Rotating Antenna Logo
Top QUANTUM FX Electronics - Others Experts
Are you a QUANTUM FX Electronics - Other Expert? Answer questions, earn points and help others
