Question about Whirlpool Dryers
PDF instructions for replacing a Whirlpool model 279816 Thermal Cutoff Kit
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Posted on Feb 20, 2008
SOURCE: Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Posted on Nov 13, 2008
jsrock516
  • 5911 Answers
SOURCE: Estate by Whirlpool Dryer TEDX540RQ1
Check your exhaust ventilation for clogs.
A simple test that you can try is to remove the exhaust duct from the back of the dryer and attempt to dry a load of clothes like you normally would. The air coming out of the back of the dryer should be forceful and warm (about 140 degrees F).
If the air flow is good, temperature is hot and the clothes dry normally, then you need to inspect your ducting from the point where it leaves the back of your dryer, to where it exits your home. Check for any kinks, bends, sags or anything else that may create a choke point where lint can accumulate. In addition, you should be using semi-rigid aluminum ducting. It is crush and kink resistant, resists heat well and resists rodent intrusion.
If the air leaving the back of the dryer is weak, then you need to check the air blower housing INSIDE the dryer for obstructions.
Leaving a dryer in a clogged condition can actually cause the heating circuits to overheat to the point of failure. Not to mention, this can be a fire hazard.
Lastly, if you replaced the TCO, did you additonally replace the Hi-Limit Thermostat? These two components are mounted on the outside of the heater box and work in conjunction to regulate the heating circuit. It is strongly recommended that if either of these two components go bad, you replace BOTH of them at the same time to prevent premature failure of any components you replace. I've seen it happen on numerous occasions where someone buys the kit, but only replaces one of the two components and later ends up with a non-working dryer again. That is why they are often sold as a kit. You can find the kit at appliancepartspros.com for about $20 (part number AP3094244). Just type in your model number and look under the "Bulkhead Parts" heading for item 6.
If you have any questions/comments, please let me know. I hope this helps you.
Posted on Jul 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool cabrio wed6200sw0 dryer runs, won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
What number thermal fuse and thermostat will work on kenmore elite model 11o 23032 dryer
thermal fuse 3390719
Thermal cut off and high limit kit 279816
Operating thermostat 3387134
Jan 22, 2017 | Kenmore Dryers
How do I install part #279816 which technician said replaced 3399693?
Hello. Here is the link which includes a video on how to replace the thermal fuse kit for the dryer. http://www.appliancepartspros.com/whirlpool-dryer-thermal-cut-279816-ap3094244.html. I hope this helps you.
Aug 24, 2015 | Dryers
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Sep 16, 2010 | Kenmore Dryers
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
