Question about Boating
2000 Mercury 40 HP outboard motor will not start, how do I trouble, for electircal and fuel problem, where would I get troubleshooting instructions? Thank you
Where would I find some type of electrical and fuel directions on troubleshooting for fire and fuel problems Thank you, DD
    Problem Solver:
  • 14 Answers
Right, Fiirst establish what is wrong.
1, is there fuel? check the spark plugs after trying to start, they should be slightly wet and smells of fuel.
2. is there spark? take out a spark plug leaving attached to wire and earth ( use a rubber handled tool or you might get a shock)the plug where it is meant to be screwed into the motor, look for a bright blue spark.
It is from here you will track down your problem.
If no fuel.....check all fuel lines then filter then fuel pump then carby bulb on bottom of carby this is the reservoir that has a float that moves a pin to stop and let in fuel in as it rises and falls. clean everything as you go. take off whole carby and soak overnight in a carby cleaner product. if you locate a prob as you go it might solve your problem but while you are at it you may as well service it at the same time. Get new gaskets or make your own from gasket paper or use gasket glues. put it all back together this should only take 30min to do as long as you have right tools. excluding soaking time.
If no spark, this is harder to diagnose as there are more fiddly parts, volt meter volt meter volt meter.......everything! check wires everywhere for loose connections, electric start? cdi unit small black box? wires coming from flywheel ,these send a charge to battery when motor is going and a charge to spark plugs via coils or cdi.
Posted on Apr 21, 2014
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
My 40 hp mercury outboard motor starts fine then cuts out once its engaged in gear any ideas
check spark plugs, add seafoam fuel treatment to fuel tank or try some carb cleaner
Dec 28, 2017 | Mercury Boating
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Why wont my 50 hp mariner start ?
renew spark plugs,mix up some fresh fuel,put choke on,throttle set at just above idle,pump up fuel bulb by hand till tight,put outboard in a water drum,try pulling or turning on starter till it fires,then push choke in and restart
Jul 25, 2014 | Mercury Gear Set, Complete, Mariner, Force...
Looking for Troubleshooting and instructions manual to find problem and repair a 2000 Mercury 40 HP that will not start
remove spark plugs and check compressions are over 100psi then put plugs back in plug caps and hold them against the head and crank over and see if they spark ! if yes then remove carb airbox cover and open the throttle fully and sqwert some fuel in the carbs try to start then with 1/4 throttle and choke on ! if starts but then dies then you need to clean the carbs and fuel pump , check diaphrams not hard !
Apr 15, 2014 | Boating
1976 115 hp mercury outboard motor manual
fuel goes in at connector then to fuel pump then to carbs ! remove connector off fuel line and prime fuel up so you know you got fuel ! then reconnect to engine and prime up again till you see filter filling and bulb should harden , then remove a drain screw from carb bowl and prime again and see if fuel comes out of all carb drains ! if yes then start engine with or in water with kill lanyard on if ok then good ! not then check sparks on all plugs putting them against the head for earth and crank to check ! if ok then i would remove carbs and clean the jets etc ! compressions 100psi or more on all cylinders ! less means recon pistons etc !
Jul 28, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
244 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
