Question about JVC MX-GC5 CD Shelf System
Centerpiece Error When I plug it in, the led's around the cd, fm/am, and aux/usb buttons light up as well as the lines on the side of the display. However, no words are displayed. It will sit like that for a few seconds then shut off on its own. Please help.
3 Suggested Answers
silly girl
  • 513 Answers
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Posted on Jan 24, 2006
gopakumarg43
  • 75404 Answers
SOURCE: When I turn on the
Hello
Hello
The microprocessor inside may confused either due to enormous external commands of by any external electrcial field. just unplut the device from AC power plug, and reconnect it again after 5 minutes or so. If this process does not solve the problem, the internal power suppy section of the set have some trouble with it. If there is less or absolutely no voltage to the microprocessor memory section, the processor cannot go forward after switch ON, and will shut down. If so the set need service. Get it serviced by any experienced service technician or by the authorises service center for JVC. OK.
Posted on Jul 29, 2011
All led lights are going side to side no sound
Make sure you try out all sources using the remote.
Press repeatedly to switch between
AUX 1,
AUX 2,
LINE IN and
FM Modes.
Mar 28, 2016 | iLive It082b 2.1-channel Stereo Sound Bar...
I can not get the auxiliary to display on my deck, How do you get the auxiliary to display?
In standby mode press Menu botton at least one second, "MENU" is displayed, with the control knob push towards FM or AM and look for "AUX OFF" item, then push toward > to select "AUX ON1", to exit press Menu botton. After this procedure the auxiliary input should be available as a sound source.
Mar 08, 2011 | Kenwood KDC-MP2035 CD Player
How do you get to the aux feature
I have the answer for this problem...finally! This is by far the dumbest instruction manual ever. Here goes:
while in standby mode, push and hold down the menu button until the display changes. Once the menu is up, toggle thur (using the am/fm toggle) until you come to AUX OFF, now toggle it to AUX ON. Exit the menu. Plug in your ipod and push the SRC button until AUX is displayed and enjoy.
Jan 08, 2010 | Kenwood KDC-MP2035 CD Player
What happened with this unit, I mean it gives me sound on fm or am, however on cd, usb, aux option does not, even though it displays in the screen it is playing.
It sounds like it could be the sound chip. If your fm/am radio is playing sound then the internal amp is fine however CD/AUX functions use a separate sound chip. Have you wired it to an external amplifier?
Dec 18, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
How do you work the aux input? im trying to connect my ipod to through an auxilary cord but im not getting any results?
Oct 23, 2009 | Kenwood KDC-MP2035 CD Player
BeoSound 9000: Similar problem, AND no AM/FM/Aux either
sorry nothing straightforward springs to mind.A dealer repair seems the only solution.
Sep 16, 2009 | Bang and Olufsen Audio Players & Recorders
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them.  This is what they tried to get people to by them.  I was never a fan of this system as the sound quality was never better than listening to FM radio.  There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into.  This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash.  All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs.  Problem is, the sound quality was only as good as FM radio.  A pretty poor way of getting CDs into cars.  But they sold millions of these things.  If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected.  if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around.  Good luck.  If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Jan 02, 2009 | Marantz ZS5300 6-Channel Amplifier
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
JVC MX-GC5 CD Shelf System Logo
35 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
