Question about Sharp AR-M277 Black and White Copier
Sharp ar-m455n print transaction report after fax
  • 163 Answers
SOURCE: Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Posted on Sep 16, 2007
SOURCE: Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Posted on Jul 17, 2008
  • 990 Answers
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
  • 54 Answers
SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Posted on Apr 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
Oct 20, 2011 | Sharp Office Equipment & Supplies
I DO NOT WANT A TRANSACTION REPORT AFTER EACH FAX
Press the custom settings button, select key operator programs, enter the key operator code (factory default is "00000"), press fax settings, press fax default settings, press transaction report print selection setting. on this screen select to print at error only.
Oct 26, 2010 | Sharp AR-M277 Black and White Copier
Transaction Report that includes portion of the fax in AR-5127, not only in error - is it possible?
In fax mode, touch the [SPECIAL MODES]
key.
Touch the [TRANSACTION REPORT] key.
If you want the transaction report to print regardless
of whether the transmission succeeds or fails, touch
the [ALWAYS PRINT] key.
Touch [PRINT ORIGINAL IMAGE] checkbox
Touch the outer [OK] key.
Oct 20, 2010 | Sharp AR-M237 Copier
How can I print a transaction report for faxed items
Press SYSTEM SETTINGS
select Admin Password and enter the password as "admin" and OK on both screens
Scroll to LIST PRINT (ADMINISTRATOR)
Select IMAGE SENDING ACTIVITY REPORT and select FAX. This will print out the log up to a maximum of 200 events ( Tx, Rx and failed sendings)
If you want a transaction report printed for each individual transmission:
Enter Admin mode as above
Got IMAGE SEND SETTINGS
FAX SETTINGS
TRANSACTION REPORT PRINT SELECT SETTINGS and select Single Sending / Broadcast etc and PRINT OUT ALL REPORT
Press OK then CA to exit
Feb 18, 2010 | Sharp MX-2700N Color Copier
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
I have a sharp ar-m455n and it is stuck on 59% memory on the fax. There are no faxes pending it has been like this for quite a while. Repairman says its ''normal'', but I have had 100% memory before. what...
Something the fax received into memory has corrupted its RAM or it received bad data/info. You can clear this problem by going into service mode by pressing the following keys : (PS. you must be in copy mode) P * C * then enter 66 and "start" then you can use "7" to try and print out what is stuck in memory or enter "10" to clear out the image memory then press "start".
Reset copier after that and you should be good.
Mar 22, 2009 | Sharp AR-M455N Copier
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
Sharp AR-M277 Black and White Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
