Sound wont work in any mode and screen is pulsing
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Backlight inverter board fault. Check and replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 17, 2014
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
94 camaro wont start...no firefrom the coil has new icm , coil , fuel pump
Check the icm plug with a led testlight for pulse while the engine is cranking. Test the wire connector with the small wires going into the coil for pulse.The v8 has a opti-spark distributor behind the waterpump that is prone to failure. It has the pickup inside it that tells the icm when to spark. If no pulse at icm distributor is bad. If pulse at icm but not at coil, icm or wiring between icm and coil is bad.The coil also needs pos.+ power on 1 terminal to operate. Be SURE to check the security light on the dash. If VATS [vehicle anti theft system] fails its usually within the 2 wires going from the key chip in the ignition tumbler to the body control module. Mine were purple and tan.Trying to start it with the wrong key can put it in lockout mode also. There are bypass modules available online for vats problems or you can even install a resistor in the wire to bypass the keychip part and the door alarms still work.
Mar 27, 2014 | 1994 Chevrolet Camaro
My washer makes a loud pulsing noise when not being used,as soon as I pull the trigger it works fine.
sounds like your unit has a bypass problem either needs adjustment or replaced
Oct 14, 2012 | Karcher Garden
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
My Garmin Forerunner 305 quit working at mile 15-ish during my 26.2-mile journey. There was a faint sound but the screen was blank. It doesn't seem to charge. I tried soft reboot by pressing on the MODE...
Try hard reset.
Hold mode + start for ten seconds (device off beforehand). Keep holding then pulse push lap/reset button.
You get a screen asking to return to default settings. You will loose all your data, but device should work then
Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
How to change from pulse dialing to tone on vtech 5.8GHz
Here are the instructions for one vtech phone (may not be quite the same as yours but may work or give enough hints for you to figure it out):
Press PROG.•
Press ? or ? until the screen displays DIAL MODE: and the current setting.
Press SELECT. The current setting blinks.
Press ? or ? to select TONE or PULSE.
Press SELECT to save.
Mar 22, 2009 | Vtech 5.8GHz Analog Cordless Phone
No sound
Sometimes, an electronic pulse can cause this protect mode. this can come from an electrical storm or, bad circuitry in the home. Unfortunately, you may have to repackage and send back to the manufacture for repair.
Jan 26, 2009 | Audio Players & Recorders
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Switching from pulse to tone and reverse
once tone/pulse appears there should be a way to hi light/select or choose either one.you must set it into memory. after it is stored, you shouldn't have to set it again before making other calls.
hope this helps
wg
Feb 10, 2008 | GE 29385GE1 Corded Phone
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
