My thermostat wont stay on and then it says -AC? how do I get it to turn on heat?
    Problem Solver:
  • 17 Answers
Did you check if ground exists at your outlet?
Posted on Apr 17, 2014
Would a closed thermostat stop the radiator fan from turning on when the temperature is within heat range.it turns on when I turn ac on,is that a different cause when not using ac.
There are two different thermostats--one in the cooling system, and one just to turn on fans. The AC has a separate circuit to turn on fans regardless of engine temp, so tind the the fan thermostat and test it.
Jul 03, 2016 | AC Cars & Trucks
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Heat stays on with thermostat off
How Your Car's Heater Works (Or Doesn't) ' AC Pro
acprocold.com/blog/car-tipstricks/cars-heater-works-doesnt/
At A/C Pro, we're focused on helping people stay cool with our do-it-yourself car A/C repair kits. ... dropping, drivers are switching off the A/C and turning on the heater. ... When you turn on your car's heater, the hot coolant flows from the engine to ... Or it could be that the thermostat, which is a valve that regulates the flow of ...
Heat Won't Turn OFF: troubleshoot the room thermostat ...
inspectapedia.com/heat/Thermostat_Stuck_On.php
Here we discuss how to diagnose & fix a thermostat that keeps calling for heating or cooling when it should not. A separate article, HEAT WON'T TURN OFF, ...
Oct 06, 2015 | Cars & Trucks
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
Heat pump wont come on
Make sure you have power to the outdoor unit. The outdoor unit on a minisplit powers the indoor unit.
Dec 13, 2013 | Carrier Heating & Cooling
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Replaced thermostat now ac wont work 2003 trailblazer heat stays on
The thermostat is under the alternator. Remove Neg. battery cable, positive cable from alternator. Remove Alternator, drain radiat
if it can't help you i think you should buy a diagnostic tool and make a diagnostic by yourself or you can do it in a garage. there are a lot of good tools here: chinasinoy.com
hope it can help you!
cheer!
Nov 04, 2012 | 2003 Chevrolet TrailBlazer
Have an electric furnace only one coil is glowing. Wont heat house any more
Turn off the thermostat and turn it back on and reprogram it. if doesn't solve the problem then turn off power and open furnace and look for loose wires. when finish this operation turn on power and check system again. if still doesn't heat call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
My ac unit wont turn on or off after i changed the thermostat
Sounds like it isn't wired correctly. Check wiring diagram that came with thermostat. Also check to be sure thermostat is for both heating and cooling.
Jan 26, 2010 | Honeywell Electronic Programmable...
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
