Question about JBL PRX618S Speaker PA Sub
Need service repair manual
Need service manual,i contacted JBL and they are not getting back to me
Where can I get a service/repair manual?
We would need to know the make and model to refer you to the manuscript, but if you contact the manufacturer directly they should help you out.
Apr 05, 2016 | Music
Service manual for the roland piano kr375
Your best bet would be to contact Roland directly to obtain a service manual. Go to the Support link at the top of this page- Roland
Jan 15, 2015 | Roland Music
Jb leon515 one speaker cutting out after about 1 hour
It's probably a thermal problem with a component. You should take it into a repair shop as it is not user serviceable.
Oct 01, 2014 | Jbl Eon 515 Eon515 15 Powered Portable...
Serious Doubts of NuMark Authorized Repair/Dealers
This is normal practice. Manufacturers keep the service information in house and only supply their agents.
Mar 15, 2014 | Numark Industries Numark 5000FX 5 Channel...
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
Power went out. believe fuse is blown.
If the fuse is blown, then there is a failure that requires servicing. Unless you are adept at electronics, take it to a repair shop. Here is your service manual:
http://elektrotanya.com/jbl_eon15g2_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Jul 30, 2011 | Harman Kardon Harman Jbl Eon515 Powered...
I have a set of JBL TR225 I need to take one of the woofers out but cannot figure out how to disassemble it. It has no screws to support the grill or the back side. Any info are links you can give me will...
Often there are small screws retaining the grille... sometimes they are black and hard to see. Other times the grill sits in grooves at the side and one has to "buckle" the grill outward to disengage the edges from the grooves. Sometimes the metal grille has rubber strips at teh edge and when reassembling, they need to be restored to the grille before it is "buckled" to get it back in the grooves. One needs to use a medium sized flat bladed screwdriver to pry up the middle of the grille at one of the two free sides and get it out of the grooves.
May 06, 2011 | JBL Bags JBL Sub Transporter Case Speaker...
I have a set of JBL control one speakers and the foam suspention has decintergrated can i get it repaird
You need to have the speakers re-coned. Unless they are really really good speakers this will cost you almost as much as new ones. A JBL authorized repair facility should be your next call. Replacing them is probably the answer
Jan 20, 2011 | JBL Control 2P Monitor Studio Active
JBL PRX618S Speaker PA Sub Logo
43 people viewed this question
Top JBL Music Experts
Michial Gueffroy
Owen Barnes
rhodesworks
Are you a JBL Music Expert? Answer questions, earn points and help others
