Question about Polaroid MiniPortrait 209 Film Camera
The camera takes a really long time to generate flash power, sometimes it does not come on at all.
  • 571 Answers
Replace batteries
Posted on Aug 18, 2009
Why does my Kodak pixpro fz41 sometimes a round orange light appears before I take the flash picture. Other times it doesn't do it.
This sometimes indicates that the exposure is correct for the distance of the subject. Remember that the flash on your camera is really only effective up to 3 - 4 meters
Feb 10, 2015 | Kodak PIXPRO FZ41 Compact Digital Camera -...
My nissin di466 block my Canon 450D. After couple shots or sometimes after 20-30 shots with nisin attached and turned on on my Canon, the camera block, I can not take a picture the AF did not work. Turning...
my Nissin Di466 had all the lights playing up at the back with nothing really working. I took out the batteries to find one had leaked. have know cleaned it up with it turning on ok, but dose not work on camera through ttl. Will not flash when shutter pressed.
Oct 01, 2010 | Nissin DI466 Power Zoom Speedlite Nikon...
I have a 3.5kva generator (wold powerking) only used 3 times spent 8 months still in box. Starts up but wont produce power!
Hi and welcome to FixYa. I am Kelly. When a brush type generator sits for a long period of time they sometimes require a field flash to get the generator producing power again. You can do this with something as simple as a 9V battery (difficult method) or a hand drill. I would recommend the hand drill. What you do is start the generator with the drill connected and the output power turned on. Once up to speed turn the drill by hand rapidly several times. (This generates a field) Mind you the drill will take off at normal speed once the generator starts producing power so please don't have a death grip on the drill chuck as you rotate it. The bigger the drill the better (more field power)
If this does not get you going again just respond here and there are other ways we can get your generator to start putting out power again. I doubt given your usage that there is any real problem with the circuitry.
Thanks for choosing FixYa.
Kelly
Aug 13, 2010 | Electrical Supplies
Shutter button causes camera to turn off
It is usually a battery strength issue. Try this, set the flash to "no flash" mode and try to take a shot. If it works with the flash set to "off", the batteries are probably not strong enough to power up the flash and shoot. If that doesn't work, try really, really GOOD batteries. Most of my customers with this problem solve the issue with Energizer Lithium AA batteries. We sell lots of these batteries, and it usually solves the problem.
Mar 11, 2009 | Fuji FinePix E500 Digital Camera
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash Setting on camera
time to bite the bullet and read.
flash is probably the most difficult thing to master in photography. and usually high end camera manuals are smaller than the manuals for the flash units that they use.
over brightness is a result sensor settings. if the camera is looking at a dark area, it will ask the flash for more light. so, see if you are using spot metering, which lets you pick a small area of the subject and set the light and exposure for that area. if it is, then be careful where it is pointed. if you are set for a more broad metering, your camera will call for an averaging of the area probably nearer the center, but take into consideration the entire frame. the book will guide you as to how the camera is set to 'see' the subject.
read, read, read. its not really hard if you take a little at a time.
good luck
mark
Dec 23, 2007 | Olympus Camedia C-350 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Flash won't power up
Try it with a NEW fully charged battery
Nov 17, 2007 | Pentax Optio S5i Digital Camera
Polaroid MiniPortrait 209 Film Camera Logo
Top Polaroid Photography Experts
Myrddin R Emrys
Myrddin R Emrys
NOEL
NOEL
David Payne
David Payne
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
