Question about JVC GY-HM600U ProHD Compact Handheld Mobile News Camcorder -
I cannot see picture on a monitor when I connect my GY-HM600U via SDI output..
I have set the A/V Set//Video Set// HDMI/SDI out" to "SD" Record format is also set to SD. I've set up my old Sony SD camera using the same cable/connection and monitor and it works.
SOURCE: JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Posted on Aug 16, 2007
TVtechmaniac
  • 140 Answers
SOURCE: hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Posted on Sep 11, 2007
  • 5 Answers
SOURCE: record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Posted on Nov 14, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
Video monitor
you connected the sound via optical spdif .......if the reciever has HDMI use that if not....select the correct device by going through the receivers selector .....ie: AV, DVD, CD, etc etc...you will find the picture when doing this. should work, also ensure the Tv source has been correctly set as the "SOURCE" on the tv remote.
Feb 03, 2014 | Kenwood VR-409 Receiver
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
Trouble connecting Ps3 to Viewsonic N3240W Via HDMI cable or RCA / AV ?? No picture... How to get it to work ?? NEED HELP ASAP !!!!!!!!!!
Just had this problem myself.
Has been solved by connecting PS3 to a working monitor.
Go into video output settings on your PS3 and selecting a video output that is no more than the maximum resolution of the new monitor you wish to use.
Eg. 576p or 720p
Oct 11, 2010 | ViewSonic N3240w 32 in. LCD TV
I can't seem to get it to record any shows off my t.v.
the hdmi connections are input only.
if the tv has scart sockets on the back, and the recorder also, connect to these. the tv's scart needs to be either 2 way or out put shown with an arrow pointing out of a box for output and a 2way arrow for 2way scart.usually scart socket 2 is 2way. set the recorder as you would normally but set the channel to tye av or scart that you are using. please note that video plus will not work on the scart socket. you may also have to set the output for the scart socket via the menu.
Mar 12, 2010 | Televison & Video
JVC GY-HM600U ProHD Compact Handheld Mobile News Camcorder - Logo
48 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
