Question about Panasonic Televison & Video
HDMI input on tv not working
The one and only HDMI input on my 2006 Panasonic projection TV will not work. changed cables and devices to make sure it was the input. When problem began, cables would not stay in. would slouch and loose connections. had to set just right and make sure no one sneezed. now wont pick up anything. this TV has been great and I love the sound and unique features. I have fixed it through fixya before on issue with eprom board replacement that panasonic was aware of and replacing under warranty but not advertising the problem. that was causing color bubbles on the screen. i'm not ready to give up on this TV and hoping the fixya community can help me again! thank you!
    Sergeant:
    Champion:
  • 214 Answers
It sounds like the jack is wearing out. Have had several jacks fail this way and some can replaced on the PCB if you can find an identical jack to replace it.
Posted on Apr 17, 2014
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
ladywinn
  • 5138 Answers
SOURCE: Panasonic 47" rear projection TV
If your set is still under warranty then get it fixed now other wise it will cost 300.00 or more to fix. replace nte 2973 mosfet transistor [2] capacitors 1200pf 2k volts.these caps are not hard to find look for burnted next to high voltage & convergence plugs ins.
Posted on Dec 21, 2007
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
  • 159 Answers
SOURCE: panasonic PT-61LCX65 tv has color spots
if you mean color spots size of a dime or so.
  • easiest: it is dust in some step of the projection light path.
  • hardest: the light engine could be damage
if you mean little ones as little dots (a neddle punshing) red and blue but always there:
  • condition call it: pixels always on: light engine is the reason.
as you see the light engine is the main part here, IT is expensive repair. so if you can survive with those little dots do it.
IF it is dust, is good idea asking for and estimate to see if can works.
Posted on Apr 18, 2009
SOURCE: Color spots on 61" LCD Panasonic rear projection tv
rowdie1 is correct. You just need to call panasonic (number on website). Have your model and serial number handy. You have to go through several holds but you will eventually get scheduled for a service call with local authorized dealer. Tech takes the back cover off and plugs in a eprom reader/writer. Turns on TV. I sit and watch the dot go away after about 4 minutes. He lets it run for about two more minutes then all done. On service ticket is says "installed corrections". And best of all, no charge!
Posted on Jul 22, 2010
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
Feb 18, 2015 | Toshiba 62HM195 62 in. HDTV DLP TV
My Insignia Blu-ray DVD player and our Panasonic DVD player are playing only the sound with no picture. We put the correct imputs on the TV. They were playing fine a few days ago. We have Charter cable....
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
Feb 13, 2018 | Zenith DVB312 DVD Player
Component to HDMI Converter Problem
Does the TV have a plug connection I think is called DVI. There is a DVI to HDMI adapter that also needs an audio connection on TV to work. Other option is audio and video rca cables. You may also need to change input connection to correct source, as it may not be auto for connection
Jan 03, 2014 | Panasonic PT-47WX42 47" Rear Projection...
Lightening was close, felt it came into the room.
If you have used the same cable in the old TV, the cable is not the cause. Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Panasonic Televison & Video
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
