Question about Ultra Hardware Ultra 44860 Jimmyproof Lock With Shutterguard
Directions for installing #44860 deadbolt
The directions are pretty useless and do not show needed views. everything is ready to go but there is no information on how/where to put the backplate. Also it is not clear where to drill the hole ( large round one and the hole in edge of the door
    New Friend:
  • 23 Answers
Measure 60mm back from the edge of the door, drill a 32mm hole.
Fit the cylinder, check for length of tailbar (you may have to shorten)
Fit lock body, lock strike onto lock, close the door, and mark where the striker needs to be fitted.Rebate strike into door frame.
Posted on Apr 30, 2014
Kwikset smartcode deadbolt newly installed unlocks when lock button pushed. I have taken batteries out and reset few times with no success.
"I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?"
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
These instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
These locks are made to work on a door which, when you stand outside and face it, has its hinges on either the left-hand or right-hand side of the door (= door "handedness").
The jumper controls that for the appropriate installation. Yours is set wrong!
Jul 10, 2012 | Kwikset 907 907-11P Venetian Bronze Smart...
Deadbolt will not function
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
Good luck--and please provide feedback if this helps!
Oct 09, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
My bioaxxis bd1 finger print deadbolt lock had to have the batteries changed. I removed the batteries and left the batteries out for a day. Once I installed the batteries, the lock would not work. I get an...
Here is the link to the website for the manufacturer, Axxis Biometrics:
http://www.axxisbiometrics.com/products/locks/deadbolt-fingerprint/bioaxxis-bd1/
I want you to have that because if all else fails, you'll have the contact information for further assistance.
Here is the direct link to the installation and programming instructions, which includes the beep codes. You likely lost the programming when you left the batteries out for such a long period:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Hope this helps. Good luck!
Aug 08, 2011 | Deadbolt Bioaxxis Bd1 Biometric...
I am trying to replace brass Schlage deadbolt locks with black. I need to adjust the deadbolt from 2 3/8 to 2 3/4 before I install the deadbolt. I can not get the deadbolt to turn in the groove.
Home Depot has a template and tool that will make the hole bigger, it comes with everything you need except a drill. I think its around $20. It clamps on to the door and has the holes alighned to be drilled. Good luck. remember, it is important to get the holes centered!
May 15, 2011 | Garden
How do I reset the code on my powerbolt/Electronic DeadBolt...by qwikset...???
Jan 11, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do you change code on Kwikset 907 keyless deadbolt
For troubleshooting:
Notice that the above may be a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kiwkset can't determine which side the deadbolt should lock. Read an answer on FixYa that said "Reverse the battery" but I knew that wouldn't power it up at all. Help?
well, if you are able to use the deadbolt manually ( with key and the inside latch ) then it sounds like everything is lined up right. the only thing that I can think of is that the computer needs to be re-programed and/or the spindle was in the wrong position when the hardware was put together(?) --- if I remember right, the deadbolt bolt needs to be retracted when everything is put together. if I had the directions in front of me I could walk you through the reset process ,, but I am not at the lockshop, I am out in the middle of nowhere Alaska taking care of a lodge for the winter--- but if you can e-mail me the exact model number of the lock I will pull up the info and then I can walk you through it. there is a way to totally erase all info in the lock and start from new. I do know what you are going through and I have ran into this problem before on the job -- I just can't remember everything about the Kwikset manual ( we mostly installed Schlage hardware and their programing is a bit different ). again, send me the model number and we can go from there. thanks,
c...
Dec 29, 2010 | Garden
My Powerbolt 1000 only works with the key in the deadbolt lock. I have a code entered that unlocks the deadbolt only with the key in the deadbolt. Your help is appreciated.
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Oct 17, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Trying to install the keypad and deadbolt. I do not have directions Thanks
This link:
Oct 02, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Hunter 44860 touch screen temperature override
"Hunter" says it all. Throw it out and buy a honeywell, robertshaw, or a white-rodgers. Hunter stats are notorious in the business as being problematic.
Oct 07, 2009 | Heating & Cooling
Ultra Hardware Ultra 44860 Jimmyproof Lock With Shutterguard Logo
59 people viewed this question
Top Ultra Hardware Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Ultra Hardware Lock and Locksmithing Expert? Answer questions, earn points and help others
