Question about Samsung ML-2570 Laser Printer
Printing business envelopes
How to set up printer for printing envelopes
  • 157 Answers
The printer does not need to be set up really, its all controlled by the software you use ie. Microsoft word. Just put the envelopes in the envelop feed if it has one or take the paper out of the tray and put the envelopes in (adjusting the side guides to fit). In microsoft word there is a function to print envelopes
Posted on Jun 19, 2009
    President:
  • 828 Answers
If your using microsoft word your can setup the settings of your envelope, and looking at envelopes and label...it not in the word... shoot it.. i mean make some adjustments
How do I set up my Epson Stylus C88+ to print envelopes? Now it is printing on the left side and my envelope needs to be on the right side. It is a business #10 envelope.
Turn the envelope in the printer. There is usually a small image on the envelope drawer. At least on Canon printers there is.
If you have MS Word, you can go Tools Envelopes and Labels
Oct 01, 2015 | Broderbund The Print Shop 3.5 Deluxe -...
Print envelopes 350
was the computer os updated, 8.1 to 10 or ?????
try this
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 20, 2014 | Konica Minolta bizhub C351 All-In-One...
Envelope orientation wrong for # 10 envelopes
It may be necessary to go back to the initial set up and make sure landscape printing has been selected. Also, envelope feed orientation could be a factor.
Dec 21, 2013 | Mysoftware My MailList & AddressBook...
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
May 14, 2010 | Canon ImageRunner 3025 Black and White...
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Select Face down .
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    LEXMARK X1240 WON'T PRINT ENVELOPES
    I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
    Jun 01, 2009 | Office Equipment & Supplies
    My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
    There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
    May 17, 2009 | Lexmark X2600 InkJet Printer
    Cannot print envelope on MX310
    Note:
    • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
    • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
      Note:
    Printer Driver Settings:
    1Select Envelope in Media Type.
    1. Select the size for envelopes.
      * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
    3. Select Landscape in Orientation.
    Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    Samsung ML-2570 Laser Printer Logo
    312 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Victorman
    Victorman
    jasbo
    jasbo
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
