Question about Kitchen Ranges
Admiral wiring diagram
OVEN WONT LIGHT
    Top Expert:
  • Kitchen Ranges Master
  • 36,427 Answers
Maybe Admiral can supply a diagram.
Posted on Apr 17, 2014
Admiral stove is electric oven came on byitself also start beeping i unplug the elements but still the peeping
You have a short in the wiring. I would not reccomend using the unit til it is sorted out.
Feb 27, 2014 | Kitchen Ranges
Admiral wont heat
Your breaker in the breaker box has a double pole breaker for the stove one breaker is shot so you still have 120volts which runs the lights 240volts for the elements.Turn main power off and replace the breaker. To verify for sure pull the stove out and unplug it check power at the plug you need 240volts at the plug. If i dont have a plug and wired straight in disconnect the wires and check the wires.
Sep 01, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Whirlpool oven: oven bulb popped and oven wont work. I already replaced the bulb. Does it have a reset switch? The stove top still works fine. The gas wont come on in the oven so that I could manually...
Sounds like you have an open cicuit in the oven power. The control for the gas uses the impedance of the hot surface igniter. Check for a circuit breaker. The wiring diagram should be inside the control panel cover.
Jul 07, 2009 | Kitchen Ranges
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
LGR3330ADB Admiral touchpad display does not work
Usually this is due to a bad main clock/electronic control in the control panel but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
https://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 27, 2009 | Ovens
WON'T SPIN DRY
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Dec 17, 2008 | Admiral AW22 Top Load Washer
Admiral Electric Oven Control Panel Issue
that is a part number to the clock assy, assuming you have 110v to L1 on back of the clock and no display , that s a preyty safe bet youll need to replace that clock assy
Nov 09, 2008 | Admiral AAV7000A
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
