Question about Brother Office Equipment & Supplies
Paper jam had paper jam removed all paper red light still comes on and says paper jam
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Posted on Mar 30, 2010
Reset
Check again. Some small piece(s) may still be there. Turn off the printer to help it forget its previous status.
Nov 09, 2013 | Sharp AL-1551CS Printer
Paper jam showing red light
did you get a full sheet of paper back out when you removed the jam? If not there is still a small piece of paper in the machine. You will need to get a flashlight and look carefully in the center of the path from where the paper starts (the paper tray) to where it comes out when it is done. if you cannot find any do this: best if you open and close all doors and lids. even the doors behind the printer if there is one. If that does not help try this: Turn off the printer, unplug, count to 10 then plug back in and restart. If the light is still on then light is saying a sensor is seeing a piece of paper or thinks it does. It is possible while you pulled the paper out you pulled a sensor flag out of its holder. By pulling the paper out opposite the paper moves through the machine can cause this. always try and remove a jam with the flow of paper, in other words the same direction the paper travels not backwards. Once fixed can prevent this failure in the future.
Jul 10, 2012 | Xerox Phaser 3117
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
I removed a paper jam. red light is still on (not flashing).
There is probably still paper stuck in the paper path, this is very common. What happens if you load it with paper and press the test button?
Feb 08, 2010 | Samsung ML 2010 Laser Printer
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
19 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
