Question about Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
Washer machine shows "ND" and doesnt got in to spin cycles or drain water out
Stops in the middle of cycle and displays nd when you turn it back on to run, it runs for 10 minutes and chimes and displays nd and doesn't full drain the water out of the tub.
    Novelist:
  • 150 Answers
The most likely cause for your issue is excess debris in the pump strainer, or a bad impeller on the pump. If you have a front small trap door on the front left or right, follow the instructions in your manual for cleaning out the trap. If the trap is empty, or does not exist on the exterior, you may need an experienced repair man to open the machine up to get to the pump strainer and check the drain pump. Pleazer Appliance...
Posted on Apr 18, 2014
  • Paolo Torres Apr 19, 2014
    Check you drain pump filter. It may be clogged. It is down in a hatch on the bottom front of your panel. If this does not work maybe you would have to have your drain pump changed.
TheMobilian
  • 8220 Answers
SOURCE: Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Posted on Apr 24, 2010
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 1122 Answers
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Posted on Apr 24, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
Front load washer
Quoted from Samsung FAQs:
"If your washer is beeping, and the display is flashing "Nd", your machine is showing a no drain condition which is usually related to a backed up drain hose or a clogged debris filter.
Follow this link for more information.
Apr 16, 2012 | Washing Machines
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer has stopped mid-cycle with water in the drum and the door locked. 'ND' is flashing on the display. How dod I get the cycle to re-start?
"ND" refers to a No Drain issue . check for restrictions in the pump assembly, restrictions in the drain hose, loose wire at the pump, or it's a bad pump.
Jan 06, 2011 | Maytag MAH8700A Front Load Washer
The washer goes through the entire cycle and then just before it should be finished....it signals ND - sounds as if it is stopping then unlocks. Only problem is....there is still water in the basin....it...
ND stands for No Drain. This can be cause by 2 things, first being the rotor on the drain pump is broken or falling off. Second, there could be a piece of clothing partially clogging the pump so it works sometimes but not always.
Dec 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Dec 24, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
160 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
