Question about Sony Bravia KDL-32ML130 32 in. LCD TV
Intermitant audio static
Responds to playing with up & down and mute.
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 17, 2014
Testimonial: "Is there an audio board? If not, which board is the audio on?"
  • The Knight
    The Knight Apr 17, 2014
    Follow the speaker connection. Trace it ,and see where it oes. That is the audio output board. To some models, audio output circuit will be a part of the main board.
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
I have no sound just static and picture
Nov 22, 2014 | Televison & Video
My gv47lfhdtv has picture but no sound has static noise
My Hannspree Hannsbook has an audio problem when running on battery power. Music gets intermitent static/distortion whether it's an mp3 file I play in winamp or streaming audio from Pandora. It doesn't...
It's quite simple... Just change your 'power plan scheme'. Try using "High Performance" (located: win7, RHS corner,in notification area; winXP, Control Panel, Battery saving). Good Luck!
'A precise description is vital for a valid answer.'
Feb 12, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
I have a problem can someone help me please i had my headphones on and somebody touch me and from the static of the bodies my headphones only worked on one ear i bought new headphones thinking that that...
you might have to tick the mute box the try your microphone first before unticking the mute box
control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Dec 10, 2010 | HP Computers & Internet
I have a Motorola H681 that used to work fine, now i can still pair with my iPhone, and all buttons seem to work (volume, call button) but there's no audio. During a test call the iphone shows the volume...
I was having the same problem - I ended up just playing with it until it worked again. I found instructions on muting the H700, which is to tap both volume buttons at once. I did that a few times while on a call (I was actually listening to my voicemail), and then I hit the volume up button, and now it works. Not sure if something is loose inside and all I had to to was play around to get it back into place?
Feb 17, 2010 | Motorola Mobility H681 Bluetooth Headset
Audio is on mute.
yes also u can check the mute from the right down icn of sound its a small speaker beside clock
Feb 27, 2009 | Enzer ET-8402 DIRECT MEMORY KEY/MUTE...
I am unable to get speakers working.
There is small logic to resolve or to narrow down the Audio issue.
Let me explain.
First, try to play any audio file and observe if is giving any error message or it seems to playing without sound.
If it gives any error message like "No Audio/Media device installed or found", then the audio driver is not installed in the computer or the Windows Audio serviceis stopped.
If it seems to be playing without sound, then somewhere it might be muted or Sound level might be lowered.
If you are sure that all settings are okay and not Muted, then you have to check with another speakers or headphones.
If another speakers works, then the issue is with the ols speakers.
Please get back to me if you need more information on this issue.
Aug 09, 2008 | Gateway Computers & Internet
Microsoft lifecam 1.4 does'nt respond
are you sure your microphone isn't muted?. Check your microphone volume setting by doing this:
Control panel > sounds and audio devices > click the audio tab across the top.
Under 'sound recording' , click volume. turn your volume up on the selected device. you may even need to change the selected device to the correct one. Play arround with that audio screen until you get it to work
Regards
Tony
Feb 27, 2008 | Microsoft LifeCam VX-3000 Web Camera
Error code 6 & error code 4
Error 6 & 4 it means laser is not reading the disc and unforutunally you need to replace the pick up laser assy.
You can get it from pacparts.com,but I reccomend you to take to a proffessional tech because this is a "static sensitive" item.
Dec 08, 2007 | Clarion DX-515 CD Player
Sony Bravia KDL-32ML130 32 in. LCD TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
