Question about KitchenAid KIRS608BSS Induction Electric Range true convection
Kitchenaid range feature not available - KitchenAid KIRS608BSS Induction Electric Range true convection
Is there any aftermarket spark module available for a kitchenaid KGCS-1340P
Contact a local small appliance repair shop they will know this info and can supply the parts if available.
Sep 28, 2016 | KitchenAid Kitchen Ranges
Kitchenaid kera205pss convection oven feature not working
Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
Apr 20, 2014 | KitchenAid KERA205PSS Electric Kitchen...
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
My kitchenaid kgrs505xss oven says feature not available
I had this problem. Turned off the circuit breaker about 5 minutes. When breaker turned back on, was able to reset
Apr 15, 2012 | KitchenAid KGRT607HBS Gas Kitchen Range
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Kitchen aid KGRA 806 PSS The " probe temp" words and icon feature on our Kitchenaide KGRA 806 PSS freestanding gas stove/oven will suddenly start to beep and flash.
This is a common issue and cannot be troubleshooted. The only way to fix this is to replace the temperature probe. The error will disappear and the range would start working fine.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 28, 2010 | KitchenAid KERS807SSS Electric Kitchen...
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
Kitchenaid KGSA906PSS gas slide in
GO TO THE WEBSITE TO GET THE PROPER
INSTRUCTIONS FOR YOUR UNIT AND WHAT
CLEANERS CAN BE USED FOR YOUR UNIT.
Mar 07, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Open Questions:
KitchenAid KIRS608BSS Induction Electric Range true convection Logo
24 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
