Question about Microwave Ovens
No heat in microwave
Fridigidaire professional
  • 33 Answers
Do the basic checks for power into your microwave.
Are you getting power in to the microwave?
Posted on Apr 19, 2014
Why is my microwave not heating model Frigidaire GLMV169dsc microwave not heating
Hello friend, thank you for your inquiry!
Sounds like there could be a potential problem with your magnetron, capacitor, or control panel inside of your Frigidaire microwave and that is why it is not heating. I would recommend seeking assistance from a professional for additional assistance towards a proper diagnose of your appliance. -Matt
Sep 22, 2014 | Microwave Ovens
Frigidaire microwave professional series
If its the magnatron I suggest a technician
Apr 18, 2014 | Microwave Ovens
EW30MO55HS Electrolux 30"microwave doesn't turn or heat
Good Morning Jody, thank you for your post!
If your Electrolux microwave (EW30M055HS) has power but does not heat, often the possibilities include one of four culprits:
·Power Supply
    ·Plugged into GFI Outlet
    ·Faulty Control Panel
    ·Faulty Magnetron
I always recommend resetting your microwave first. You can do so by unplugging your appliance or flipping the circuit breaker for about 30 seconds and then turn your microwave back on. If your microwave stills does not heat or turn, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Feb 19, 2014 | Electrolux EW30MO55HS 30" Built-in Drop...
Microwave wont heat
Hello - If the microwave does not heat, it could possibly have a faulty control panel, magnetron or an issue with the power supply. Contact a professional to move forward accurately.
Oct 19, 2012 | Frigidaire FMT148G1 Microwave Oven
Microwave is not heating
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
Put 1 cup of water in the microwave and set it to heat on full power for 1 minute. Repeat the process with fresh water several times. If the water is not consistently warm, you've confirmed there's a problem.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
Otherwise, there may be an issue with the circuit board and its connections. If a qualified professional determines that the circuit board is defective, the most practical fix may be to buy a new microwave.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
utube.png You-Tube video "_3SbJueEn1w" placeholder
Sep 28, 2012 | Prestige Appliances Microwave Ovens
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Ikea Lagan microwave not heating. Lights and fans work but food doesn't heat up. Was working okay a couple of days ago but now not heating.
Microwave Electronics or magnetron failed, you will need to have it looked at professionally. Sorry.There may be a fuse inside but it will be a thermal fuse which requires professional replacement.
Please Vote
Feb 03, 2011 | Whirlpool Microwave Ovens
My microwave is no longer putting out any heat
The problem could be caused:
top door micro-switch
or
Answer: First, make sure your microwave is plugged in and getting an ample supply of power. If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate.
If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Warning: Microwave ovens are probably the most dangerous of consumer appliances to service due to the very high voltages (up to 5000 V) at potentially very high currents. If you have any doubts about your knowledge and abilities, replace the oven or have it professionally repaired.
Oct 06, 2009 | KitchenAid KCMS185J Microwave Oven
Not heating
it could be the magnetron, or the diode or the capacitor but mostly it is the magnetron..
tnx,
drcool
it would be better to call a professional when handling microwaves...
Jul 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Will not heat
The magnetron or one of the smaller components like a resistor(s) or capacitor(s) may be kaput.
Best to take it in for servicing by a qualified professional, as opening the microwave can be risky and hazardous to health, if you are inexperienced in these kind of matters.
Cheers
IrishDruid
Apr 28, 2008 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
