Question about Hobart A200 Stand Mixer
Can anyone help please ....i bought an used A200 the motor run fine ... as soon i load it up it run slow and didnt want to run ... after i open the cover up ... evrything looks fine ,wondering what the problem ...?
  • 1,511 Answers
Jeff: If you can expose the interior of the motor housing and check the wiring on the windings; you may find that someone may have cut or changed the original connections. It sounds like you are applying full power and getting a reduction of speed as a result of a shunt along the way.
Posted on Apr 17, 2014
What's the ML number of the unit? Look on the serial number plate. We need to identify the year and model before assessing the concern.
Testimonial: "serial no 1738775 model a200"
  • 4 more comments
  • sang vong
    sang vong Apr 17, 2014
    serial no 1738775
  • Jeff Pritz Apr 17, 2014
    Can you take a picture with your mobile phone of the serial number plate and upload it here?
  • sang vong
    /Users/GiaDinhBuiDoi/Pictures/iPhoto Library.photolibrary/Masters/2014/04/17/20140417-194006/IMG_0053.JPG
  • sang vong
    sang vong Apr 18, 2014
    yes it looks like someone did change the power cord on it
  • sang vong
    i'll try to upload the pic later... thx for your help
  • sang vong
    This is the SN...
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
How to change hobart a200 motor bearings
Do not heat up you have to strip the gear box but not all take the top gears off but look what you are doing its got to go back the same way or it won't work you have to take the worm gear off and then you can take it out from the back but if you can't do it get in touch with **** at x bakery in Haywood and ill sort it for you hope this helps it is a big job sorry
Jan 06, 2013 | Hobart A200 Stand Mixer
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Jan 04, 2011 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
I bought the slicer and shredder set for the KitchenAid stand mixer, no instructions were in the box. What speed do I use the attachments on?
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
Dec 05, 2008 | Hobart A200 Stand Mixer
Mixers eating brass gear driven by motor pinon
Thats called a sacraficial gear because its brass which is a soft metal.This gear takes most of the strain but i think either a spacer is missing or the gears arent meshing correctly.The transmission assembly the shaft next to it make sure all the spacers/washers are there.Goto hobartcorp.com you will find an exploded parts breakdown.
Aug 29, 2008 | Hobart A200 Stand Mixer
Hobart A200
Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
fritz
Jul 26, 2008 | Hobart A200 Stand Mixer
Motor runs but beaters won't turn and gears will not engage or change speed
Most likely there is a broken shaft, seized bearing, or a stripped gear.
The service tech will unassemble everything and replace the necessary warn or broken parts. He will re-assemble everything, check for proper gear lash and bushing clearances, and re-pack new grease.
Jerry G.
Apr 30, 2008 | Hobart A200 Stand Mixer
Motor replacement for A200
If the motor runs and when under a load the planetary stops its not the motor.You either have a sheared key or broken gear in the transmission.
Mar 22, 2008 | Hobart A200 Stand Mixer
A200 240 volt mixer
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted alex@fixya.com (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email1.gif him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Mar 17, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
171 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
