Question about Hardware & Accessories
Theben tr 610
I m looking for a manual regarding the timer theben tr 610, but it is an old model (not a TOP) with 6 buttons
2 Suggested Answers
  • 3289 Answers
SOURCE: I would like to replace five Intermatic wall switch timers (model WG230-6) that are not presently working.
The Intermatic E1020C timer is a 120 volt, single gang, single pole switch. This means it must ONLY be used on 120 volt circuits (to operate the internal timer motor), will fit into a standard electrical swithbox (does not require over or double sized boxes) and will replace a standard, single pole switch ie: has ONLY two terminal screws (not including the green ground terminal) and if a toggle type - has ON and OFF on the handle. The only additional requirement is that the switchbox will need hot (often black or red) & neutral (nearly always white) power in wires and hot (again, black or red) and neutral (again, nearly always white) power out (to the light or fan) wires. Many times, these devices are wired a little differently - with just 2 wires - instead of the four cited above. This is to provide power to keep the timer motor operating. The manual for this switch can be downloaded (and printed) here.
The part number of the old switch you provided does not appear to be correct. This number lends me to believe that it is for a 220-240 volt circuit. The closest I could find to an Intermatic part number was WG230-13. This part is the timer motor for replacement on a differnt style timer. It is indeed a 220 - 240 volt clock motor as I suspected. Please double check the brand and model number once more.
Lastly, if you can not find the info requested above, you should be able to replace the old timer with the new style - provided that the installation requirements cited in the first paragraph are met. Shut the power off before removing timers and switches and test with a working meter to be sure.
I hope this helps & good luck!
Posted on Nov 21, 2011
How to wire a theben 24hr timer
Generally theben timers are wired same as illustrations shown on following pages
Wiring varies slightly by exact model number.
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Most these timers are rated 15 amp.
Safe maximum :: 15 amp x 80% = 12 amp
230V x 12 amp = 2760 watt
For best long-term result, use timer to turn on a contactor (relay) and let the contactor handle switching heavy amp load
Fuse-protect the timer by adding inline fuse to hot wire going to timer.
Gene
Jul 14, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
The 64B 240v 50Hz 16A theben timer is not turning lights off
Copy following link for analog 24-hour timer:
http://waterheatertimer.org/How-to-set-timers.html
Is this new timer, or older timer with worn-out trippers?
Or is this the theben digital timer.
Add a comment and describe timer in detail for more possible assistance
Apr 20, 2013 | Hardware & Accessories
Hi, I have a Noma moonrays 88 watt timer with two buttons on the front and a display from 0 to 9. the top button seems to be a manual/auto switch and the bottom one has a clock symbol, but i can't
1) Copy following link for to identify timer, and possible instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#Moonray
2) Add comment and say what you discover about setting timer
3) Look on timer, and sometimes the instructions are printed on paper label
Dec 09, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I am trying to program a Westinghouse yard stake. It's a model 28006, hinge top, 6 outlet digital photo cell. Please help if you can.
1) Copy following link to help identify same-similar timer and download possible manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) On-line search shows dawn-dusk timer which can be set to turn off 1-9 hours after dusk.
Typical operation is to push button until 6 displays, then timer turns ON at dusk and OFF 6 hours later
3) Describe timer with more detail so expert can exactly identify timer functions and find same-similar manual.
Dec 03, 2012 | Hardware & Accessories
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
Do not know how to use Theben time switch.
I have theben timer sul181h. How to set it for lighting automatically at 6p.m. and stopping at 9p.m.?
Apr 30, 2010 | Hardware & Accessories
I am looking for Trenton TR-T2VPCI 92-005449-OX S/N: 13994. REV:K-06 Main Processor for replacing the old one which is connected to a CT Aura. Will U find one for me?
Unidec repairs industrial automation electronics such as Trenton Technology 92-005449. Contact them at service at unidec.com or call 610-353-3221
Apr 01, 2009 | Office Equipment & Supplies
Diplomat 610 electric oven has no power and won't come on. is it a fuse in the oven? As power to it has been tested and is fine.......
I have a diplomat select 610 oven
at present it has a mind of its own, with regards to turning off snd on.
I have mislaid the manual for working the timer etc. can I obtain a copy of instructions, rather then buy a new oven when this one works perfectly even though it is approx ten years old.
Thank you.
Lyn Lloyd
Dec 11, 2008 | Kitchen Ranges
Hardware & Accessories Logo
113 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
