Question about Nortel T7316E 2-Line Corded Phone
Access call pilot manager - Nortel T7316E 2-Line Corded Phone
    Problem Solver:
  • 28 Answers
Hi Kathryn,
I'm assuming that you mean you want to be able to edit the system's voice mails and AA.
Feature 983
The default password is 102000 for two digit extensions, 1020000 for three digit extensions.
Posted on Jun 15, 2014
Where is the pilot?
There should be a door way or access panel, remove that and pilot should be inside.
Nov 01, 2014 | Water Heaters
Pilot light on 1954 wedgewood gas stove burns too hight how to adjust
There are small screws on the manifold that control the pilot fame. They could be accessed by removing the top panels or sometimes they can be accessed from the front , Some of the front panels snap off. remove the burner tops and trace the tubes back to the valve manifold and you should see a screw on a small valve. Turn these and the pilot lihght should go up or down.
Oct 01, 2014 | Kitchen Ranges
Youtube
Replace the top regulator plate and gasket on the gas valve, the four main burner orifices, and the pilot orifice. You need to remove the main burners to access the orifices and disassemble the pilot assembly to access the pilot orifice.
Jul 25, 2014 | Pitco Frialator Kitchen Appliances -...
HOW DO YOU LIGHT THE PILOT FOR THE OVEN? OVEN I
Remove the oven floor & the access panel below the door,inside of lower access panel their will a gas valve with a red button on it, push red button,light pilot burner connected to main oven burner,hold red button for 15-20 seconds,release red button and pilot should be on.reinstall panels
If you release red button and pilot goes out the thermocoupler needs to be replaced
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Imperial IR-6-C Elite Gas Kitchen Range
Record greeting
What kind of voice mail system do you have? They all are limited to the amount of total storage available. It probably has one or more mail boxes that are full and using up your storage. If it is a call pilot 100 or 150 and you have call pilot manager access, you can click on "message usage" under the reports menu and it will tell you the current storage available. Hope this helps.
Bill C www.dyna-tech.us We also offer remote programming and tech support for the Norstar CICS, MICS and the Call pilot 100/150.
Mar 16, 2010 | NorStar M7310 Corded Phone
Currently, my phones rings 3 times before my voicemail kicks in. I would like to change this to 1 ring.
If you have a call-pilot 100 or 150, access the call pilot manager. Then go into the Autto Attedant menu and select line administration. You will see each line listed and the ring count displayed.Click on "change" on and then adjust the rings. The call pilot manager is a GUI you access inside the call pilot through the cat 5 plug with a crossover cable. The default IP is 192.168.110.11 with a mask of 255.255.255.0. default logon is 0000.
Bill C. www.dyna-tech.us We also offer remote programming for the Nortel CICS and MICS.
Mar 15, 2010 | NorStar M7310 Corded Phone
Missing pilots
First, what are pilots ? If you are meaning flag's or exclamation mark's, that’s something else.
Remove all your external devices and restart your unit.
Next, go to your device manager and if you see the phrase " unknown device " remove it.
Next, if you see a red flag, open the device and remove it from the list, one at a time, ( do not reboot until finished.)
If you see a exclamation mark or mark's, please remove them as well.
Ok, reboot your unit and allow it to load whatever drivers and devices it may see.
If while loading the devices, you receive a statement, can't find correct drivers, you will have to go to ACER and download the correct drivers for your operating system.
Hope this has helped you.
Nov 17, 2009 | Acer Aspire 5610 Notebook
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Burner & pilot went out, will not go without having a gap in the burner access door
Replace the pilot generator and everything will work again. It is a problem with it sensing the flame from the pilot and when the generator stops working it tends to knock everything out
May 30, 2009 | Rheem 30 Gallon FVR Propane Water Heater...
Sync Palm Pilot Contacts to Blackberry Pearl
generate a file from the palm pilot program. I think there is a application within palm pilot specifically for that purpose. Once you have generated the file move it to your blackberry manager program and sync the phone
Dec 24, 2008 | RIM BlackBerry Pearl Smartphone
Nortel T7316E 2-Line Corded Phone Logo
55 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
