Question about Fasco Bradford White Water Hot Heater Exhaust Draft Inducer Blower # 239-40614-00
Noisy barring motor
Very loud hen blower i srunning, is there a way t oreplace the barring or just the motor, gettin gquotes over over $500 to replacve th eentire enducer.
    Sergeant:
  • 213 Answers
Bradford white blower . Sir this link will provide you with a variety of sources to buy the blower. The average is far below your quoted target. Since this is a nut and bolt with a direct plug or 3 wire assembly, bradford white blower 239 40614 00 . Here lies a different price point.
If this blower is out of warranty and its been running a long time. The value of the direct replacement is a far better choice to average, although more, odds; are to revisit it sooner than later without a direct replacement.
If you need help to do this job? It can be a do-it -yourself. Make sure the unit is locked out and give it a whirl. If not? The replacement is approximately 2/3 that of your suggested quote. The ball is always in your court.
Be safe. Carbon Dioxide does not discriminate, you never hear anyone from the cemetery complaining. If this is iffy. Get a technician. The extra 1/3 may justify the worth of a life investment. Fare. Well.
Posted on Jun 09, 2014
4A Slow Blow Fuse keeps blowing in my Prestige Triangle Tube 110 Solo LP with U125
Jack,
I just got mine fixed, so can for sure try to help you.
Something on the low voltage side is misbehaving. I can walk you through narrowing it down if necessary, but it's most likely the blower motor.
Here is how you can confirm. Unplug the wiring harness or harnesses at the top of the blower motor. The plastic can be brittle, so be gently. This will remove the blower from the equation. Then, start up the boiler. Did a new fuse blow? If not, it's the blower motor.
If there is a tube attached to the blower intake, remove it. Then stick a screwdriver into the small hole where the air sucks in. Try to rotate the fan. Is it stuck? Does it spin freely? You might be able to free it and get heat for a while, but you will probably need a new blower kit if it's noisy or stuck.
Post back if you need more help.
- Paul
Feb 22, 2015 | Honeywell Triangle Tube Prestige Solo 110...
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Exhaust blower
If it has no oil ports, replace the motor
Dec 02, 2013 | Fasco Bradford White Hot Water Heater...
Loud noisy boiler what's wrong with it ?
Hi. I'm not an expert but most of my boilers in the past get noisy when they get air in the system. Underneath your boiler will be an inlet tap to top up the sysem with water. Make sure you bleed all of your radiators of air till they squirt water then keeb topping up the system and bleeding till no air remains in any of the radiators. There should be a pressure dial on the front of your boiler and there is usually a red fixed needle which shows what the opperating pressure is. I would do this before anything else and see if this solves the problem. :-)
Apr 29, 2013 | Water Heaters
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Feb 10, 2009 | Fasco Bradford White Hot Water Heater...
Fasco Bradford White Water Hot Heater Exhaust Draft Inducer Blower # 239-40614-00 Logo
203 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
vince
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
