Question about Goldstar MV-1526 Microwave Oven
How do i go about changing the fuse inside? - Goldstar MV-1526 Microwave Oven
    Sergeant:
  • 249 Answers
You have to remove the unit cover ,should be close to where the wire goes into the unit
Posted on Jun 19, 2009
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
Working perfectly until I put the 2nd mince pie into machine. No power so I changed fuse on plug but nothing. Has it just worn out? David
You may have an inline fuse inside microwave. You need to remove the casing of the microwave to see if there is another fuse inside (usually near the magnatron) If there is a fuse there then there's your problem, if not, then there is no use in trying to repair since the magnatron unit has possibly gone bad.
Hope this helped you
Dave
Jan 29, 2010 | Sharp R-206 800 Watts Convection /...
The house fuse that runs the circut the microwave is on blew when replaced the microwave did not come back on,is there a reset button or fuse on it.
There is a fuse inside the microwave oven but i don't recommend opening the oven and changing it. There are high voltages inside even when the oven is disconnected from the mains.
But if you are careful enough, you can change it. If it has a electronic control (With a digital display) maybe there is another fuse on the controller board, near the front panel.
Before even opening the oven, make sure it doesn't work on another power outlet.
And make sure you change it with the same type and rating of fuse!
Oct 27, 2009 | Magic Chef Microwave Ovens
Changing a fuse, Hard?
well its not very hard to do,,, but,,, what caused the fuse to blow?
what fuse has blown as there are at least 3 of them in there, none of them are the same size as a 13 amp plug and most are of the slow blow type,,, even the hight voltage fuse!!! (ei:1000's of volts!) if a fuse has blown its most likely to be the unit getting near the end of its life, and sufferd whats called a "flash over" maybe on the capacitor or the megatron both would pop a fuse, but it will only do it again!! and that next time it could go with a big bang and stink your house out for weeks with a burning smell!!!! and if you dont know what not to tuch inside of this microwave dont go inside of it, it could easly kill you, even with the plug pulled out the wall scocket, there will still be 1000,s of volts kicking about inside of it,,, whats your life worth??????
microwaves are only £50.00p up now,, play it safe buy a new one
Oct 21, 2009 | Maytag MMV5207A Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium mircrowave oven
The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
Changing a fuse in a Galanz 700W Microwave Oven
A microwave casing can be removed and almost full access to the electronics with about 6 screws.... make sure to unplug it from the wall first.
please vote on your answers to keep the site free.
Sep 04, 2017 | Microwave Ovens
Can't reset nothing works at all
Did you try to change the outlet
If yes, try to change the Fuse inside the mw
But make sure to unplug the MW first
May 11, 2008 | Microwave Ovens
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
268 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
