Question about Brother MFC 210C All-In-One InkJet Printer
Printing incorrect colouring
Does not seem to printing with the cyan. Everything is pink
  • Anonymous Mar 23, 2014
    i am customer of bizhub c224 when i printing a matter left to right cyan colour deep to light
    New Friend:
Still have a diffrent colour
Posted on Dec 22, 2012
  • 832 Answers
Plz check the color carts: are they inserted at the right place? If not, change them into the right place. Run the cleaning cycle 4 times to get the wrong ink out of the tube and nozzels.
If you have them at the right places print a test print by pressing ink button and selecting the test print.
Does it look good or do still have the diffrent colors?
Posted on Nov 02, 2007
Mfc 495cw printer is printing everything pink. I just replaced all the color catridges. how can i fix this?
Try a Nozzel check to see what colours are missing. I would assume that Black, Cyan and Yellow are missing since you are only printing pink. Then do a Printhead Clean to clear the other nozzels.
Dec 19, 2015 | Brother MFC Office Equipment & Supplies
Cannon mp560 photos are printing all a pink colour
it sounds as if one or more of the nozzles of your printhead is dried or blocked. I would advise printing printing a test page like this one to clarify the cause.
Assuming one of the colours is missing (i would imagine it would be cyan or yellow) then run some head cleans from your printer software or the printer itself.
Sep 06, 2012 | Canon MP560 All-In-One InkJet Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I have a hp 6500. It has started printing pink instead of black.
Either:
* printers mix in a bit of "colour" ink when you request BLACK,
so that the colour ink-jets do not dry-out. So, since your BLACK has become EMPTY, all you get is PINK,
or,
* some printers mix colours to produce BLACK-ish colour.
Check that your CYAN and YELLOW ink-cartridges have not gotten to be EMPTY.
Jul 17, 2010 | Office Equipment & Supplies
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Not printing cyan
cyan colour in Cartridge may be thick/ ctrdg faulty
Aug 08, 2009 | HP PSC 2355 All-In-One InkJet Printer
Everytime I change my print to grayscale it prints in pink
Not knowing what sort of printer you have it's hard to pin-point exactly what the issue may be. Taking an educated guess I'm going to guess that you are using an inkjet of some sort. These printers will often use a combination of the cyan, magenta, and yellow inks to make black and shades of gray, and it is possible to get pink instead of gray if the cyan and and yellow are to low to provide a mix to produce gray. Try new ink cartridges to see if that makes any difference...some printers, like DesignJets use individual cartridges for each colour, and most small printers use a combination cartridget that contains cyan, magenta, and yellow ink in different reservoirs in the same tank.
If you are using a printer that doesn't require both the colour cartridge and the black cartridge in to function, try pulling out the colour cartridge and printing in grayscale. Most printer drivers are designed to recognize the fact that the printer only has the black cartridge in it and will automatically make the necessary adjustments.
Jul 27, 2009 | HP Office Equipment & Supplies
Installed a new cyan cartridge, but the blues show up as pink..
I can assure you that you got a bad colour ink cartridge. However, you may try this: get a small ply of tissue paper and place over the printing head, with your mouth and some good measure of pressure **** it. Repeat a couple of times and all the three colours: cyan, magenta, and blue will show up; otherwise replace immediately. Good luck
Apr 30, 2009 | Xerox Phaser 6180N Laser Printer
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Jun 12, 2008 | Office Equipment & Supplies
Colour of print
A New printer is the most cost effective answer here- they are so cheap No repairs are possible You could check out www.fixyourownprinter.com but you will fiddling around with various suggestions -is it worth it?
Jun 16, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Brother MFC 210C All-In-One InkJet Printer Logo
287 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
