Question about ASUS Notebook
Connecting i tunes to a mixing board for output sound
How do i connect an apple i mac to a pioneer djm 300 mixing board, and do i have to change any of my mac settings
Recording from DMX 6fire distorted
try isolating the usb that you are using by removing all unnecessary items like extra headphones, cellphones, speakers, battery backup usb connection, you name it. More than likely the static is from that. or try a different usb port if you have removed these items
hope this helps
Feb 19, 2014 | TerraTec Electronic Terratec DMX 6fire...
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
How do i connect a pioneer djm 500 mixer to a dbx 215 equalizer
You can use either (2) XLR mic cables or (2) balanced 1/4" cables running from the Master Out of the djm 500 to the dbx 215. Then you connect your amp to the outputs of the dbx 215.
Joey Clay
Oct 14, 2009 | Audio Players & Recorders
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
One Output low on DJM 400
This may not be the correct solution, but have you checked the switches on the back of the DJM-400 to see if one output is set to "PHONO" mode?
Apr 17, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer djm 600
There is a master gain volume control on the rear of the mixer, where you connect everything. Make sure it's not down.
If it's fine, then maybe them being outside caused an issue. How cold is cold? If your talking freezing, then maybe there is some issues with the solder on the pc boards. You'll have to take it to a service center at this point.
I would say, try connecting a CD player to all the channels, and try from there. If it's still the same, then you need professional help.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Oct 02, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
ASUS Notebook Logo
383 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
