Question about Kenmore 22422 Top Load Washer
The water turns brown. I have checked the hoses and detect no coloring.
You may have a tub seal leaking from transmission. Check out YouTube under washer leaking oil. You may see what the problem.
Posted on Apr 17, 2014
Starts beeping and flashs h and f in display
F/H Error Code = No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oil has a light brown color
Most oils are light brown in color. If it does not look normal check the oil cap and the radiator cap when it is cool. . Turn it over after you take it off and look at it. Does it look like there is water in it? If so, you could have a blown head gasket.
Dec 11, 2010 | 2000 Pontiac Firebird
Code F and code H what do they mean?
Or
    3. Check inlet valve operation
    1. Check Drain pump operation
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check pressure switch operation
  • Check flow meter operation
  • Check CCU operation
Nov 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code F H flashes
Following are the reason for F H code
1.No water detected entering machine or Pressure switch trip not detected.
2.If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check the following things
1.Make sure that both valves at the water source(s) are turned on all the way.
2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3.Check inlet valve operation
1.Check Drain pump operation
2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Check wire harness connections to Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check CCU operation
Thank You
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The FH error keeps coming up.
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting a beep and a blinking F what does that mean?
just an "F" is a default code ( meaning for some reason it cannot detect the problem ) ... try this, if not succesful call a tech to test the main control unit...
Or
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message :fh
(((fh)))
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Replace failed component.((usually the pressure switch and corresponding hoses will need to be replaced))
Jul 30, 2009 | Whirlpool Washing Machines
Cold water rinse just trickles on my whirlpool heavy duty top loader
There is a screen inside the inlet valve that is most likely plugged. Turn off the water and remove the cold hose from the washer inlet valve. You can see the screen just inside the valve. If the particles are a light brown color, it may be water softener resin, requiring a softener repair. Foreign matter can also include sand or other particulates in the water supply.
Apr 25, 2009 | Washing Machines
Error code HF
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Verify CCU operation.
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My DLP TV wont turn on.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
