Question about JVC THS55 System
Connector cable The connector cable pins are bent and I need replacement cable
3 Suggested Answers
trububbles1
  • 54 Answers
SOURCE: Where can I get a replacement Ipod connector cable
try a radio shack or walmart eletronics or best buy
Posted on Sep 25, 2009
  • 30 Answers
SOURCE: Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Posted on Sep 18, 2015
My emachine monitor keep saying no singale
May be a bad pin (bent over or missing) on your monitor cable to the video jack on your computer. If a bent pin, you can straighten it with small needle nose pliers; VERY SLOWLY--fast moves can fracture the pin and break it. If a pin is missing (broken off), the connector must be replaced. If connector looks good, and is not a molded, but a soldered type, a broken solder joint can be repaired, If it is a molded cable, the entire cable must be replaced.
I focused on the cable because this is the most common cause of "no signal", and further troubleshooting would be 'involved', to say the least.
Mar 01, 2013 | Computers & Internet
I have a Konica Minolta Dimage A200. The memory
I can be fixed, but will be expensive. Get a local quote.
Mar 24, 2010 | Konica Minolta DiMAGE A200 Digital Camera
Our acer monitor (AL1702W)displays almost all in green colour except white but white is also with greenish shade. Monitor Sr. No ETLA708029818072674211, SNID 81802928742, MY Email Id is...
Please check the connector at the end of the cable connecting your monitor to your VGA port in your computer. Check if there are any bent or broken pins, or if the cable is damaged near that connector. If this is the case, you will need to get this connector replaced to fix the problem.
Mar 22, 2010 | Acer Computers & Internet
My keyboard stopped working
What kind of keyboard connector does it have?
If the end of the connector is round with pins (serial connection), just plug the keyboard back in and reboot the computer. With that style of connector, if they get knocked out or come loose while the computer is running, they will not always work again until you reboot.
If the keyboard uses the flat plug (USB) connector, the computer should be able to pick it up again without a reboot when you reconnect it. Also note that if the keyboard is USB and it stops working; if you have any other USB items hooked up as well (IPod, webcam, external drive,etc), check to see if any of those devices are still working either before rebooting your system. Sometimes, another unrelated USB device may crash causing ALL USB devices to fail simultaneously. If this is the case, unplug all USB devices except your keyboard and reboot. If the keyboard works again, reinstall all of your other devices one at a time until you locate the one that crashed all of them (if that was the case).
Hope this helps.
Mar 19, 2010 | Dell Computers & Internet
Ipod video pin connector bent
If it is the pins within the iPod that you are refering to, go to th following website for the replacement parts and free instructions on the process. If this is not the issue you are refering to, pease do let me know.
http://fixyouripod.weebly.com
Feb 15, 2010 | Apple iPod MA446LL/A MP3 Player
Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
May 05, 2009 | Dell 3400MP Multimedia Projector
Prolite e435s iiyama screen
Monitor screens will have color tints when any of pins of the VGA connector is damaged or bent(I assume you are using a 15 pin VGA connection :) ) Please remove the monitor connector cable and check if you have bent or damaged pin at either side of the cable.
If it does not resolves the issue, replace any devices or equipments that may have electro magnetic fields like an UPS from the premises of the monitor.
Also, you can try resetting monitor. All the monitor will have an option for reset in the Menu.
Hope this works!
Good Luck
Mar 09, 2008 | Computers & Internet
Bent pin in USB connector
call sandisk technical support. :D if its the pin of the player not the cable call them if its the cable try purchasing a new one there are lots of electronic shops out there.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
JVC THS55 System Logo
29 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
