Question about Samsung L700 Digital Camera
Why is it all I get is a white mist when taking a photo
Camera not taking photos- all I get is a white mist on the screen. Have tried changing the SD card and battery but still will not take photo
SOURCE: Samsung s850 cant copy from camera to sd card?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Posted on Jan 12, 2009
  • 8 Answers
SOURCE: 'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Posted on May 01, 2009
SOURCE: camera wont work says the card is locked
Take out the memory card and on one of the sides there is a little slider and push it in the opposite posistion and it will be unlocked and shall work.
Posted on May 26, 2009
SOURCE: I have a Samsung S760.
this is a technical problem....do try to reset factory setting ..well if it doesnt work contact your dealer
Posted on Sep 29, 2009
Testimonial: "thanks, but i couldn't reset, and its out of guarantee (by 15 days!)."
  • 4090 Answers
SOURCE: pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
Posted on May 29, 2010
Won't take/record photos!
Are you sure it is set to save images to the card and not the camera's internal memory ?
Mar 28, 2017 | Konica Minolta DiMAGE F200 Digital Camera
Samsung galaxy S3 phone camera not working..When turn on camera,no other function button on screen works & it says "camera failed"..any help? Many thanks :)
Let me guess.. you are using an external SD card, correct?
And, now you are having this camera failed issue. It's due a corruption with the SD card.
1) Go to Settings>Application Manager>(swipe right to left until you see) ALL>(Scroll down the list to "Camera") Tap on Camera> press "Clear Cache".
2) Power off your phone.
3) Take the back cover off your phone.
4) Remove your SD card
5) Restart the device
6) Wait a couple minutes for the phone to fully load. Then, re-insert the SD card.
The camera issue should be fixed.
7) go to the camera app, in the camera settings change how the camera saves photos to phone storage only (NOT to SD card, this is where the problem occurs). Doing so will help the camera take photos faster. The SD card is too slow for the camera. After taking your photos, you can move them to the SD card to clean up space and back up your photos in case your phone ever crashes or you ever become locked out of your device. I would use the SD card to back up all files not just photos.
Apr 12, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I can take photos in camera but i can't see photos in laptop
you should format memory card through your laptop, then it should be accessible to both devices, dont forget to backup data via camera cable
Jul 16, 2012 | Sony 1GB Memory Stick PRO Duo Memory Card
Hi, I have a camera, a Sanyo VPC-T1060 and it's having some problems. It turns on, flashes, takes photos apparently, but the LCD screen won't work. It turns white when I turn it on and when I take a photo...
Try to remove the memory card if used, and blowing out the connectors in the camera cavity with compressed air (to remove dust if any).
Make sure the contacts are clean. If necessary try another memory card.
I'm not sure about the lcd screen, except it may require service from sanyo.com.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Aug 14, 2010 | Sanyo VPC-T1060 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Can't take photos
Using a USB SD card-reader, copy all the photos from your camera SD-card to your PC, then try format option in your camera, this way the photos in your SD card are safe(in the computer). OR
insert a new/empty SD card into your camera. Use the format option and start clicking photos.
Dec 17, 2008 | Olympus Camedia C-350 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
DXG-506V LCD comes on Blank White Screen
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 03, 2008 | DXG Technology DXG-506V DV Digital...
Red/White Lines On Photos and LCD
HI,
The scren is just displaying the input from the CCD (Digital Sensor that actually takes the picture).. If The pictures were fine, but the screen was funky if you could live with it then there wouldn't be a problem.
Since it's on both the screen AND on your photos it points to there being a fault with the CCD
Given the age of the camera, the cost of a repair I'm afraid it's time for a new camera. there's nothing you can do to fix this yourself.
Sorry for being the bearer of bad tidings.
If my advice was at least helpful please vote for me!
Nov 19, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Samsung L700 Digital Camera Logo
18 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
