Question about Maytag Washing Machines
Washer mod# MFW9700SQ0 error code# f6
Maytag washer mod# MFW9700SQ0 error code# f6
  • Anonymous Mar 16, 2014
    Error code e1f6. Happens before spin. Never been used.
  • 6,784 Answers
Drive motor tachometer error(f-6)
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
In most cases, the MCU will need ot be replaced.
Posted on Jun 19, 2009
2 Suggested Answers
  • 109 Answers
SOURCE: maytag washer mod#MFW9700SQ0 error code f6
This is a good webpage to look at: http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC9NTU9ZLU1Bag==/sno/0
Your error code indicates that the motor is having difficulty turning.
Is the machine brand new?
If so, it's possible that the shipping bolts haven't been removed.
Note: To remove the error display, press Pause/Off or Pause/Cancel twice.
More info here: http://maytag.custhelp.com/app/answers/detail/a_id/2890/sno/0
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Looking for agitator parts for 909278 maytag style Master
There appears to be variations of this model. Here is a link to one company who may have the parts and assistance you are seeking:
Here are the model number variations:
  1. MFW9700SB0 - Washer
  2. MFW9700SB1 - Washer
  3. MFW9700SQ0 - Washer
  4. MFW9700SQ1 - Washer
http://www.appliancepartspros.com/search.aspx?model=mfw9700s
Jul 21, 2015 | Maytag EPIC MFW9700S Front Load Washer
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Mfw9700sq0 error code F11
It's a communication error.
Most of the time it's the motor control board (located inside cabinet, towards the bottom on the left), but it wouldn't hurt to check the wires going from the main board to the motor control board.
It's a Whirlpool part. Part number 8182706.
http://www.repairclinic.com/PartDetail/Motor-Control-Board/8182706/1184161
Oct 13, 2014 | Maytag Washing Machines
Maytag front load washer mod mhwe251yg00 cde e1-f6
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
Jan 20, 2014 | Maytag Washing Machines
We just got a brand new MayTag Modle # MHWE200XW00 today. We cannot get the washer to start due to error codes which are, F6, and E1. What is the problem?
It is a communication error between the CCU and the MCU. It could be just a poor or loose connection or either the motor control or computer control. try unplugging it for 5 min then plugging it in again.
Oct 27, 2010 | Maytag MAH8700A Front Load Washer
Maytag washer mod#MFW9700SQ0 error code f6
Jun 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
F6 codes mod#MFW9700SQ0 jonathan
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes. Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed. 2. Unplug washer or disconnect power. 3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 4. Plug in washer or reconnect power. 5. Check the MCU by looking for operations of the drive motor. 6. Check the drive motor for powered rotations.
Jun 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
525 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
