Question about Yard Machines Garden
Need a carborator for a yard machine 18 inch w 6hp ohv
    Loyalty:
    Visited the website for 30 consecutive days.
  • 210 Answers
They can be found on ebay or amazon
Posted on Dec 14, 2017
4 Suggested Answers
  • 468 Answers
SOURCE: Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Posted on Mar 23, 2010
Testimonial: "Nut was clogged. Now it starts but acts as it is in choke position, dont think there is a choke. Engine reves, falls, reves falls but stays going."
01fordeb
  • 1033 Answers
SOURCE: Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Posted on Mar 24, 2010
  • 143 Answers
SOURCE: Hard to start Earthquake ardisam 6.0 hp ohv briggs
Why not remove the carb. and clean it out? If it was "sitting awhile" the fuel has died and needs to be drained and renewed. You might have to dismantle the carb. and blow out the jets with compressed air. Don`t touch the OHV (over head valve) cover.
Posted on Sep 11, 2010
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
What type of oil do I use in my 6HP lawnmower?
Straight 30 weight oil is best, but a 10-30 will also work...
heatman101
Jul 17, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Hard to start Earthquake ardisam 6.0 hp ohv briggs and straton intek 206 has been sitting awhile need to clean carborator or what is ohv and plate in front of carborator. need starting instructions
Sep 11, 2010 | Ardisam Inc Earthquake Mini Cultivator
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
32 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
