Question about Morningstar ProStar Charge Controller, 30A, 12/24 VDC, w/ LCD Monitor, PS-30M
Red light flashing
ProStar 30 screen read LUD, with error 7, 9, 13, &voltage @7.2. All wire conn.are good, & test with voltmeter @batt. & lugs of controller reed 14.2 and also at batt. Charger
98 chevy malibu my alt isnt charging new alt batt test good cut out the fuselink on starter the alt wire runs thru firewall If i run a wire straight to the batt it is putting out 19v any suggestions
Did you check the fuse in the under hood fuse box ? GEN / BATT fuse 10amp . Is your check engine light on ? This is a computer controlled charging system , it should have four wires connected to the alternator . 1 - the heavier wire on the back ,this comes fro the starter - the one with fusible link , you could have checked for battery voltage with voltmeter ! The three other wires in the connector are the orange one ,this comes from the GEN / BATT fuse an should have battery voltage ! The last two come from the PCM - engine computer . The gray wire is the turn on signal from the PCM an the Red wire is the control from PCM ! Charging System Wiring Diagram MOTOR Magazine Article MOTOR Information Systems
Aug 14, 2015 | Cars & Trucks
Draw on Batt over night with all switvhes off
you might need a new battery from old age. also while its running check the battery voltage. should be around 17V, if not could be the voltage regulator.
Feb 13, 2014 | Polaris 2004 Magnum 330 4X4
In my 1980 Fiberform, I have no power to any accessories or to my ignition, and my battery seems to have a full charge.
Check battery connections. Check voltage at fuse panel. Should have same voltage as battery. If voltage is present turn on any switch, if voltage goes away with a load follow the no voltage procedure but leave the switch on while testing.
If no voltage, check for any fuses or circuit breakers in the supply wires. Still no voltage: connect voltmeter red lead to positive at battery, black voltmeter lead to negative at fuse panel. Voltage OK problem is with positive supply to panel. If no voltage connect meter red lead to positive at fuse panel, meter black lead to negative at battery. Voltage OK problem is with the negative supply to panel.
If fuse panel is supplied voltage from the ignition switch start the voltage tests at the ignition switch.
Sometimes the positive and negative supply for the fuse panel are connected at the engine. Usually the positive at the starter solenoid, if so use that source instead of the positive battery post. Voltage must be traced from the root source to the load. Both positive and negative must be isolated and verified separately. Without one, positive or negative, there will be no voltage at the load. The load being whatever needs voltage applied to function, (light, pump, etc.)
If there is a corroded connection or wire it is possible for voltage to pass through the corrosion with no load. When a load is applied more amperage is required. The corrosion is not a good enough conductor to carry the required amperage and the voltage goes away. This corrosion can be at a terminal connection, (wire to switch, battery cable to battery lug, battery lug to battery post, etc.), internally in a switch, wire, fuse or circuit breaker. It is possible for a wire to appear to be in good condition. The outer insulation can be intact while the inner conductor is corroded, sometimes turned to green powder. This is why marine grade wire is more expensive than standard wire. Marine grade wire is tinned copper, copper conductor electro coated with tin to resist corrosion.
Oct 05, 2013 | Spectrum Color Fiberform, 1980-1985, White...
2005 Ford Freestar SEL battery light coming on
take it to an accredited auto electrician for a charging system check including the voltage regulator and wiring conditin
at idle the battery voltage will be 12-13 volts and at 2000 rpms it should be steady at 14.5-14.8 volts dc
Apr 05, 2017 | Cars & Trucks
My1997sporster batt full charge conections tight, turn key on lights come on push starter button and nothing,pulled batt back out to check lines, batt sat in holder, tryed to start . It started and ran ,...
Have u checked the starter connection? Sounds like ur starter solenoid is malfunctioning, the starter relay and the starter switch.
Clean the battery terminal and the connector thoroughly.
Try to short the positive terminal connection of the solenoid and tell us wut happened.
Jun 12, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
1998 ford e150 one headlight dont work already tried new light
If you replaced the bulb and are sure the new one is good, you have a wiring concern. First you need to be sure the terminals at the headlamp connector are making a tight connection. If this is good, check for a good ground at the black wire by using a test light with the clip connected to the positive battery terminal. Touch the test light to the black wire and it should light. If ground is good check for voltage, again using the test light but with the clip on the negative terminal. Test at the red/black wire for low beams or the light green/black wire for high beam. Low beams use 10 amp fuses #'s 25 and 31. High beam uses fuse # 30 and is 15 amp. If voltage or ground is not present and the fuse is good you need to trace the circuit and repair the wire.
Apr 06, 2011 | 1998 Ford Econoline
I have a 94 merc cougar xr7 with a 3.8. the batt light is on and the volts are reading 12.38 roughly when running. the ignition wire has 12v rinning to it and the batt wire to the back reads 12v. the...
Need to check voltage at back of alternator, should have no less then13 volt's, if you do alternator is good, this is just a self test for you, with engine off, with test light check for voltage at back of alternator, test light should light up, if it don't look for blown fuse link at starter solenoid on fire wall. most of the time a fuse llink will have a tab on the wire, pull genly on wire, if it feels rubber like, bad fuse link,
Aug 17, 2010 | 1994 Mercury Cougar
When I turn the ignition on the battery light comes on and the voltage gauge drops between 9 & 14. Then it slowly goes up to around 14. I replaced the battery. Alternator??
take volt meter check voltage on batt.while truck is idling,voltage should be between 13.5-14.5v,turn headlights on it should stay in that range if it goes below,check for bad wire connection at alt.,if conn. are ok,theres a good chance alt. not charging properly!before doing test make sure batt.is full charge!
Apr 19, 2009 | 2001 Chevrolet Silverado 1500
No power, all buttons flash when connected to ac charger
if charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Jul 21, 2008 | Samsung SGH-c225
Morningstar ProStar Charge Controller, 30A, 12/24 VDC, w/ LCD Monitor, PS-30M Logo
133 people viewed this question
Top Morningstar Electronics - Others Experts
Are you a Morningstar Electronics - Other Expert? Answer questions, earn points and help others
